Thread: OBD2 socket
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default OBD2 socket
    Hi All,
    Can anyone tell me if my vectra c 1.9cdti 8v 55 reg has a OBD2 socket as I have found a car code reader with diagnostic on it for £54.95.
    Sodding Typical on Sea
    It does same place as the other models, under the ashtray
    Regular Member DaveW555's Avatar
    Cannock
    Quote Originally Posted by vectra 120 View Post
    Hi All,
    For that price its only likely to read engine management and nothing else.
    Cannock
    As I thought, you'll only be able to read engine management codes with it, if you have an abs/airbag fault its going to be useless.
    my eml is on so it should clear that
    Thanks everyone
    Full Member Big Sig's Avatar
    Only if the fault is no longer active.
    Hope so my front pipe has just been replaced (fliex pipe split) unless anything could set the EML off
  1. obd2 software
    By Mickey76 in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2013, 21:41
  2. Obd2
    By chris-green in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2011, 10:49
  3. Obd1 obd2
    By gazza3009 in forum Styling
    Last Post: 8th June 2010, 12:10
  4. OBD2 readers
    By Derek Mc in forum General Chat
    Last Post: 2nd May 2010, 08:00
  5. obd2 reader??????
    By tommoturbo in forum Troubleshooting
    Last Post: 30th September 2006, 09:36
