Thread: cd30 on/off function
    Sodding Typical on Sea
    Default cd30 on/off function
    I cannot get my head round this. I have the radio off when I leave the car I get in and the radio comes on with the engine every time?
    How do I get it to switch off with the key and then wait for me to invite it on again by the button as this thing is way to pushy!!
    I tried the ign-logic option but that leaves the radio on (if it was on before stopping and leaving the car) when I switch off and remove the key,,,,
    Cheshire
    I have the same problem mate, so will be looking for a solution also
    Redditch
    Go into the settings and there is an option for ignition - just switch it off. That way you have control over the head unit. It is in the manual but its easy to find on the settings.
    I wonder if that was the result that if it is switched on when driving, it stayed on when I stopped and removed the key? I will try again
    Redditch
    It also remembers by the key, if you can't sort it when I get a chance I'll work out the sequence to switch it off, the setting is ignition logic
    Thanks I will go have a trawl through the manual as well
  1. BC - no function
    By dmcc in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2013, 20:12
  2. Phone Function
    By RMH in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2011, 18:50
  3. Help with the Search function......
    By adz_011 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 20:28
  4. Can the egr function be deleted from the ecu?????.
    By felixx in forum Diesel Engine related
    Last Post: 26th February 2011, 18:56
