Results 1 to 10 of 24
Thread: PS3 60GB Fat Version... DEAD
    spoons
    Guest
    Default PS3 60GB Fat Version... DEAD
    Ahhh god damn...
    Got the PS3 Yellow Light of Death... playing MW2, system shuts down with flashing red light.
    Now wont turn on.... (bought the PS3 on 27th March 2007)
    Press the power button. goes green for half second, then yellow then 3 beeps and flashes red.
    Cant eject the MW2 Game CD... all dead !!
    Seen this fix on Youtube,
    http://www.youtube.com/watch?v=4_Ic1_TY-GU
    http://www.youtube.com/watch?v=Vr1zyAGwnuU&NR=1
    but you guys got any ideas first before I start attacking it with a screwdriver and heat gun?
    Full Member Big Sig's Avatar
    You can get the disk out, press the power button and then eject it before it shuts down.
    mate at work had it and has "fixed" it twice with a heat gun so far. Unfortunately eventually it will just die.
    spoons
    Guest
    You can get the disk out, press the power button and then eject it before it shuts down..
    Nope, tried this several times and it wont eject...
    I'm going to Maplins tomorrow and try my own fix., dont really want to spend another £300 ish quid on a new PS3 if I can avoid it.
    The problem is with the heat thats produced the solder breaks down and you end up with loads of dry joints. The heat gun helps to repair them - along with a little heat sink paste.
    edit: you tried this? - Turn off the system, then hold the eject button down, keep holding it down. Then turn the system back on. Do not let go of the eject button.
    spoons
    Guest
    Not happy it only lasted 3 years though....
    And one of those years I didnt use it at all !!!
    spoons
    Guest
    Thanks for your help Big Sig, its appreciated, cheers
    I'm a bit undecided though whether to just dump it and get a new one ?
    Have you seen my edit above?
    The slimline ones are better but they still do it
    spoons
    Guest
    Yep, just tried this and it still wont eject. Just goes to 3 beeps and flashing red light. It wont eject.
    Its probably a case of taking the top off then.
    Loads of the broken ones on ebay forsale too so maybe buy a new one and flog it on?
  1. PS3 60GB FAT Version - Alive
    By spoons in forum Games Room
    Last Post: 20th May 2011, 11:23
  2. Radiator - Swap an Auto version to a Manual version?
    By dae36 in forum Engine & Drivetrain
    Last Post: 27th January 2010, 17:26
  3. 60GB Playstation 3
    By Jim Bob in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 28th November 2008, 23:01
  4. 60GB PS3's...
    By BigMan in forum Games Room
    Last Post: 31st December 2007, 18:05
  5. Playstation3 60GB HELP!!
    By purple170503 in forum Games Room
    Last Post: 8th December 2007, 22:20
