Results 1 to 3 of 3
Thread: droning
    ireland
    Default droning
    hi all,renewed the rear dics and pads to my cdti 120 bedded them in nice and slow ,after 2 weeks thought ill try these babies out,stopped on a six pence , 3 days later i get a droning noise,check rear discs for warping wheels spin freely with no disc touching,went to the front and and had alittle uneven turning of the wheel on drivers side,sounded like discs was ever so slightly out of sorts,renewed the front discs and pads but noise still remains,so my next port of call is wheel bearings,just a question what does ids stand for and how do i find out if i have it,ill be hunting ebay for the replacement parts as living in southern ireland there bound to be 3 times the price of the uk.any help would be appreciated
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    First try swapping your tyres front to the back & see if that cures it as the Vectra seems prone to droning from the rear tyres
    I'm just getting a wheel bearing replaced front drivers side from chassis number 51000001 onwards with IDS, but i don't have IDS as far as i know ?, the garage i use got sent the early one so I'm still droning as the early one wouldn't fit
    Here's some info from the handbook
    Interactive Driving System-plus (IDS-plus) with Continuous
    Damping Control (CDC)
    D5. The Interactive Driving System (IDS-plus) chassis offers the
    driver an even more sporting driving experience, thanks mainly to the
    electronic control of the suspension. Pressing the Sport switch activates
    the CDC function – CDC monitors the roll, pitch and yaw of the car, and
    changes the rate of damping on each wheel to optimise the handling,
    effectively stiffening the suspension – but selectively. This means the
    vehicle will exhibit a reduced rate of roll and pitch, making it more
    responsive during direction changes and more settled during the
    braking/turn-in/acceleration transition when cornering. CDC is a
    major breakthrough in the segment.
    Sport switch
    D5. The functions of the Sport switch aren't limited to suspension
    control. When activated, it also affects the steering and accelerator
    pedal. The drive by wire throttle is altered electronically, leading to
    a sharper engine response and crisper acceleration, while the map
    of the power assisted steering is also adjusted, giving the driver a
    D5 more positive initial turn-in on corner-entry.
    Anti-lock Braking System (ABS) with Cornering Brake
    Control (CBC)
    D7. Cornering brake control makes the car easier to control in
    extreme situations, particularly when braking sharply on a bend. It is
    particularly effective when carrying out emergency procedures, such
    as avoiding a child’s ball that’s rolled out from the kerb. The system
    works by sensing the different rotational speeds of the individual road
    wheels and co-ordinating the level of braking pressure applied to each
    wheel. CBC is an integral part of New Vectra and New Signum’s
    comprehensive ABS.
    Emergency Brake Assist (EBA)
    D6. Emergency brake assist detects the urgency with which the
    brake pedal is pressed and rapidly increases the pressure to the
    maximum the system can provide, shortening stopping distances.
    It also enhances pedal feel.
    Electronic Stability Programme-plus (ESP-plus)
    D1. ESP-plus provides enhanced yaw compensation during
    understeer or oversteer. The system works by monitoring the
    front and rear of the car, comparing their respective directions
    of travel going in to the bend with the input received through the
    steering wheel. If the vehicle starts to slide, it applies corrective
    braking to the appropriate wheel, or wheels, compensating for
    the slide and helping you regain control more rapidly.
    Adaptive Forward Lighting (AFL)
    Adaptive Forward Lighting is a sophisticated new lighting system
    that allows drivers to see around corners and see further ahead
    at motorway speeds. This optional bi-xenon system employs two
    main functions:
    ireland
    cheers for info thunder, already done the wheel swop,besides i can feel something through the steering wheel and me pedals,is the plug different for a wheel bearing with ids,thinking can i locate plug and check??.
  1. Droning sound
    By vectrasri-j in forum Suspension, Wheels & Brakes
    Last Post: 3rd November 2011, 15:51
  2. Droning noise
    By HHH in forum Engine & Drivetrain
    Last Post: 18th June 2010, 20:36
  3. Droning n/s/f brake
    By Dazfoz in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2009, 07:52
  4. droning from the front end....
    By markvec in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2009, 21:44
  5. Droning from front end
    By gtr1000 in forum Suspension, Wheels & Brakes
    Last Post: 23rd November 2008, 11:34
