Results 1 to 2 of 2
Thread: rear disc and pad replacement
    Regular Member mitch's Avatar
    WIGSTON, LEICESTER, LE18
    Default rear disc and pad replacement
    Hi i replaced the rear brake set up on the vectra couple wks ago, and noticed they get hot after a journey plus brake muck on wheels, i have not noticed this before with old disc and pads., now with the warm weather i took apart again and painted the calipers. now there are still the same dust on rear wheels, plus i notice a squeeke sometimes when pulling away??? i thought they may be binnding but if you let the handbrake off on a slight hill the car rolls, am puzzled.
    Is this just them bedding in or do i need to replace the sliders and rubbers?? anyone else have this problem? thanks mitch. also am off to oulton park tomo and am a bit worried as its a hour half drive!
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Mine did the same thing mate, give them a couple of hundred miles and they should be fine.
  1. Brake Disc & Pad Replacement
    By robdd1 in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2010, 14:06
  2. Brake disc replacement
    By CrisA in forum Suspension, Wheels & Brakes
    Last Post: 2nd April 2010, 14:06
  3. New front disc and pad replacement £??
    By pauls898 in forum Suspension, Wheels & Brakes
    Last Post: 24th February 2009, 20:59
