Results 1 to 3 of 3
Thread: Poor starting and slight misfire on z22se
    Regular Member Nato's Avatar
    Risca, South Wales
    Default Poor starting and slight misfire on z22se
    Over the last couple of weeks the car has developed a nasty habit of being lazy to start from cold. The engine turns over fine, but doesn't seem to want to fire. The engine will fire and then die immediately, and then on the third starting attempt it starts and stays running. I've also noticed a slight miss on idle and have had the car cut out on me once or twice as well, but I'm not sure if the cutting out is related to the starting issue. What do we think the problem is? I'm leaning towards plugs as it is a starting issue more than anything, but could it be a fueling problem also? There don't seem to be any other symptoms, and I don't have any warning lights on.
    Regular Member DaveW555's Avatar
    Cannock
    I'd whip the plugs out and inspect them for damage first, then if they seem ok give them a good scrub up with a wire brush and put them back in, If that doesn't cure it try a new set and if that doesn't work it's probably the coil pack on its way out.
    Risca, South Wales
    I did think it was plugs, then possibly coil pack. I've just been out and checked for fault codes with my code reader as well - it's come back with 0138: oxygen sensor circuit voltage high. Something else to think about there...
  1. 3.2 GSi slight misfire, need help....
    By TimTay in forum Engine & Drivetrain
    Last Post: 19th August 2011, 11:10
  2. Slight misfire at idle
    By Lozza in forum Troubleshooting
    Last Post: 17th June 2011, 06:52
  3. 1.9 CDTi Slight misfire
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2010, 00:19
  4. Slight CDTI misfire
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 2nd June 2010, 17:46
  5. cdti 150 slight misfire! help needed
    By craigz9876 in forum Engine & Drivetrain
    Last Post: 30th October 2009, 11:11
