Thread: degreased and presure washed engine, now squeeling aux belt
    wooler
    Default degreased and presure washed engine, now squeeling aux belt
    just blasted my engine bay with presure washer, now my auxilary belt is squeeling like mad, tried wd40 on free running pully and tensioner, squeel goes away but then comes back 2 mins later, any1 had this before?
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Don't hold to this but i was informed that it could be the alternator. When pressure washing the engine water will get in there.
    Glasgow
    You have blown of all the dirt and grime that stopped it from squeeling, pressure washing the engine for me anyway is a no no.
    Full Member Big Sig's Avatar
    Wd40 will also strip the grease from the tensioner.
    Nov 2009
    manchester
    Put a bit of talcum powder on your belt
    Oct 2007
    Shropshire
    WD40 is designed to remove water and penitrate, not lubricate. It stands for 'water displacement and is the 40'th attempt to get it right!
    You need to gease up the tensioners, pulleys etc and it should stop the noise!
    wooler
    can only be the free running pulley on the alternator, didnt xctly pressure was down at the belts just cleaned the rocker cover off as it was covered in diesil, didnt exctly want the smell of fuel getting in2 the car
    Glasgow
    A good product for cleaning bits like that is a can of brake cleaner or muck off degreaser both would do a great job of breaking down the oily dirt and would only clean the area you have sprayed
  1. Aux Belt Tensioner - 2.0 DTi Engine
    By Boz657 in forum Engine & Drivetrain
    Last Post: 22nd July 2012, 23:47
  2. Engine belt change
    By korbee in forum Vectra C / Signum Troubleshooting
    Last Post: 29th March 2011, 00:20
  3. Help with getting engine mount off/cam belt
    By Mads in forum Engine & Drivetrain
    Last Post: 9th March 2011, 22:14
  4. Squeeling from engine
    By Gortreck in forum Engine & Drivetrain
    Last Post: 14th December 2010, 14:51
  5. Engine Squeeling when started, hot or cold
    By benparker in forum Engine & Drivetrain
    Last Post: 2nd August 2010, 16:56
