Thread: help needed bit of a silly question
    falkirk
    Default help needed bit of a silly question
    went to do full service on my 2.2yh signum today and found it has the wrong oil dipstick as i put in the amount of oil it says its max capacity is and it still diesnt show on the dipstick
    so any 2.2yh owners be able to help me out by measuring the lenth of the metal part of there dipstick upto the base of the yellow plastic bit just to comfirm what i think is wrong
    Mileage : 000
    I had a simalar thing with our Vectra B. It said in the handbook 4ltr. But it took nearer 5.5 to get it to the top mark on the dipstick. Even when I supplied the Mobil 1 oil to the VX dealer when they serviced it they had to open the second can I gave them. So I would fill it to the Top dipstick mark.
    falkirk
    iv put over 6 ltrs in and still not showning on dipstick so something not right
    Mileage : 000
    Quote Originally Posted by matt0785 View Post
    That does sound a lot to me I must admit. Some will go into the filter. But it does sound wrong to me. Best wait for someone with the same motor as you, to give advice.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    It should be 4.5L, possibly 5L at the most but I cant see it being much more than the SE SE mate. 6L will do more damage than good.
    falkirk
    yep not started it until i get measurments off somebody to confirm its the right dipstick its only reason i can think it isnt rading correctly
    Vehicle : SRi
    Mileage : 137000
    The 2.2 dipstick is 50cm long from the flat but under the yellow ring, the difference full and minimum on the dipstick is 1L. The tube/shaft the dipstick sits in is only pushed into the sump, it can be pulled out which will affect the reading. When checking the oil only check it 5 mins after the engine has been run hot, not on a cold engine when the oil has all drained into the sump.
    falkirk
    is that the lenth for the se or the yh as they are meant to be different ????
    Oct 2007
    Shropshire
    Remember its normally around a litre between min and max on the dipstick, I believe the rated capacity is to fill it to minimum on the dipstick? Anyone confirm?
    Z22YH
    Engine oil = 5.0 litres
    Min to Max = 1.0 litres
    You therefore need 6 litres to complete an oil and filter change
    My Y30DT claims to be 1.3 litres on Min to Max
    Was bang on the minimum mark
    It took just under 2 litres to get it to the maximum mark
  1. silly question
    By wildchild in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2012, 09:26
  2. Bit of a silly question but...
    By ijk571 in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2011, 11:26
  3. A silly question??
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2011, 12:11
  4. This might be a silly question......
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2010, 12:47
  5. Silly Question of the day
    By Ralph wiggum in forum Vectra C / Signum Troubleshooting
    Last Post: 10th November 2006, 17:40
