Thread: Boost pressure sensor screw thread
    Redditch
    Default Boost pressure sensor screw thread
    Just had a look at mine to work out why it was hesitant on boost and found that there is no thread on inlet manifold for the screw to fix the boost pressure sensor so its loose. Do you think I will be able to get it rethreaded easily or is it going to be a costly new manifold
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Had the same thing on my one, On the screw that holds it in the threads start about 1/2 cm away from the end, if so you can bye any new bolt were the threads go all the way to the end sorry can't think what size but it's a comen size and inside the manifold end were it screws in there will be plenty of threads deeper in. If you now what I mean, The manifold is soft alum and rubbish threads.
    Redditch
    cool thanks for that will visit my local shop that has loads of bolts and stuff and get one about 5-8mm longer which should do it.
    preston
    I would helicoil it personally, helicoil kits cost around 20 quid and you can do it yourself and it will be a stronger thread, steel instead of ally
    Redditch
    Helicoil is my other option and prefered but I will probably go down that route if the quick fix that will cost me pence doesn't work as i'm already strapped for cash this month, needed new glow plugs at 15 quid each it was ouch
  1. boost pressure sensor input and output voltage???
    By FLOB in forum Engine & Drivetrain
    Last Post: 24th April 2012, 14:58
  2. boost pressure sensor
    By iwtand in forum Engine & Drivetrain
    Last Post: 5th February 2012, 20:43
  3. 2.0 dti boost pressure sensor
    By jono m in forum Engine & Drivetrain
    Last Post: 3rd January 2011, 12:08
  4. boost pressure sensor
    By johnbattams in forum Engine & Drivetrain
    Last Post: 26th March 2009, 17:40
  5. Boost Pressure Sensor
    By vectravirg in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 12:52
