Thread: Fitting a clutch return spring
    Reading
    Default Fitting a clutch return spring
    Thanks to the advice on here have bought a clutch return spring for £10. Vxl want £75 to fit it but on the basis the advice here was it only takes 10 mins thought I'd do it myself.
    However, changing the wiper blades is tricky for me, so this is advanced mechanics as far as I'm concerned !
    So can anyone walk me through how to do this please? Do you have to remove the cover under the steering column, if so is that just a few screws. Thanks
    Reading
    Thought I'd just give it a go. Undid trim under steering column, have loosened headlight switch but can't figure out how to remove blue connector on back of headlight switch so I can move all trim out of way to get to clutch pedal.
    Can anyone advise, didn't want to pull too hard in case broke. Thx
    Reading
    Thanks to "mhvcbv" Found the clip that keeps the connector in. Cheers.
    Reading
    Job done, found some other pics on this site. May have taken me an hour all in but saved £75 ! Cheers
    Chelmsford
    Don't suppose you've got the part number for the spring have you? The stealers here didn't seem to know what I'm on about when I told them people on here had done the mod...
    Disregard that, I've found it...
    For everyone's info, it's 93183937, about £7 from vx apparently.
    Reading
    Quote Originally Posted by DNS View Post
    Paid £10.22, took a while to fit, easier removing lower dash panel, job done plus cruise now works as a bonus.
  1. Clutch Return Spring
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 14:47
  2. Clutch return spring, adjustable?
    By Sierra2 in forum Engine & Drivetrain
    Last Post: 20th March 2011, 18:52
  3. Clutch Return spring tension
    By Dazbaz in forum Troubleshooting
    Last Post: 20th January 2010, 12:54
  4. modified clutch return spring
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2009, 22:40
  5. clutch pedal return spring
    By smartymarty1971 in forum Engine & Drivetrain
    Last Post: 11th March 2009, 00:00
fitting a clutch return spring insignia
https:www.vectra-c.comforumshowthread.php112163-Fitting-a-clutch-return-spring
vectra clutch release spring
vectra c clutch return spring
changing clutch pedal return spring insignia
how to fit insignia clutch return spring
vauxhall insignia clutch pedal return spring
insignia clutch pedal spring
fitting modified clutch return springs vectra
