Thread: Climate controls removel and replacement
    worcester
    Default Climate controls removel and replacement
    How do you remove the console that contains the climate control buttons and fan speed?
    My problem has been the fan speed does not follow the turning of the knob and full speed (7) can be selected what ever the fan speed knob is turned and careful turning backwards and forwards will give low speed most of the time.
    can anybody help?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    grab the two outer knobs and pull straight out. motor might be sized or more likely the resistor
    Dunstable
    Is a bit tight, if you pull out the cubby hole below the heater controls, you can get under the controls and pull them a bit easier too. They just pull out.
    worcester
    Well that was quick, will try early saturday and let you all know how I get on.
    I have had that problem twice and twice in two different cars I have had to replace the control panel. It's not cheap either although the second time I struck lucky and got one from car parts conexxion - although at this time of night I can't spell it correctly lol
    worcester
    Thanks for all the advice, unit removed.
  1. Replies: 6
    Last Post: 26th June 2012, 10:58
  2. cdti oil filter removel
    By rob10 in forum Engine & Drivetrain
    Last Post: 20th May 2012, 21:19
  3. are the dual zone climate controls interchangeable?
    By appy in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2012, 23:07
  4. seat stains removel
    By yadziyad in forum Bodywork & Interior
    Last Post: 13th July 2009, 13:29
