Results 1 to 10 of 13
Thread: fitting my fogs
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default fitting my fogs
    is this correct when wiring my fog up? without a relay trouble is i want to put a relay in but i aint sure what wire go where could somebody fit one on the pic ? or do i need a relay can i fit them without a relay?
    cambs
    hi m8
    here's one with a relay
    http://www.classictruckshop.com/club...h/foglites.htm
    alot better/safer if you use a relay.
    Oct 2009
    Sandwell
    Quote Originally Posted by mhvcbv View Post
    hi m8
    yea ive seen tha the bit i dont get is the wire going from the switch to IGN for battery power, where do i wire that to?
    cambs
    Quote Originally Posted by chris1804 View Post
    you can wire that from the ciggy lighter
    Oct 2009
    Sandwell
    looking over that again i get it now that wire just needs some sort of power? how about stereo live?
    cambs
    yep that will do fine
    Oct 2009
    Sandwell
    cheers bud,
    PRESTON
    as mhvcbv says, ciggy lighter feed or any feed that is on after the ign is turned on will suffice, as its basically a signal wire to the relay and wont carry alot of load. Re the diagram, you can if you choose to run two cables, one from terminal 87 and 87a to each fog individually.
    Oct 2009
    Sandwell
    Quote Originally Posted by barney490 View Post
    yea i get it all now cheers guys, only other thing im wondering is i wonder if my car had the fog loom already there if not if i cut the heated washer leads off are they the same fit?
    PRESTON
    not sure if its there on your model chris, guess you will see when the bumper is off. Personally,i wouldn't cut the washer leads off but make up new little loom for the fogs,
  1. Help needed fitting H3 HID Fogs on to Facelift
    By Envy in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2012, 19:54
  2. Fitting front fogs
    By MadOnVaux! in forum Insignia car chat
    Last Post: 4th January 2012, 17:06
  3. fitting fogs
    By myelite150 in forum General Motoring Chat
    Last Post: 2nd December 2011, 19:19
  4. fitting SRI Fogs
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2007, 20:06
  5. Fitting Fogs ??
    By gsxrster in forum Electrical & ICE (including SatNav)
    Last Post: 8th September 2007, 19:01
