Results 1 to 10 of 13
Thread: Whiny A/C Compressor
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    Default Whiny A/C Compressor
    OK, whenever I put my foot down with the air-con on, especially when setting off, the compressor makes a horrid whiny, wailing noise which increases with speed. It's at it's loudest around 2.5k revs then drops off from there. If I turn the air-con off, the noise stops.
    I use the air-con all year round & it's usually silent, it only seems to make a noise in the hot weather, I guess the compressor is under more strain.
    I took it to Kwikfit last summer (it was noisy then, too) for a gas check/refill as it was getting cold, but not exactly frosty, especially when the car wasn't on the move. They hooked it up to their monkey proof machine & said all was fine, just required topping up slightly, but nothing they wouldn't expect to see from a car of it's age.
    So, the question is, is the compressor on it's last legs? Would a new compressor mean better cooling?
    OK, that was two questions, but any help/advice would be appreciated. It's still got a few months warranty left so if it is faulty I can (hopefully) get it sorted along with the duff recirc servo.
    Regular Member DarylAAS's Avatar
    South Shields
    Hi Mate,
    Compressors Are usually noisier in the warmer weather as there under more strain... and your aircon not being frosty is usually because it hasnt got as much gas in as it should... i usually add a bit more than recomended so its as cold as possible...
    HTH
    Trim : GSi
    Mileage : 39k
    Ah, so nothing to worry about, compressor wise? As for the low gas, that's what I thought last year when I took it to Kwikfit, the top-up/refill/whatever they did made little to no difference.
    Maybe the system just isn't up to my expectations; it cools fine when at motorway speeds, less so at 30 & under, and what seems barley cool when stationary.
    Is anyone else's the same or do I have a fault elsewhere on the system?
    Oct 2007
    Shropshire
    Mine is icey cold when stationary, just takes about 1/2"hour to get that cold!
    Full Member axelf's Avatar
    chester le street
    It sounds like we have the same problem...i am havin a trip to see Daryl to see if a topup fixes the whining.....will keep you posted....
    Full Member watchman's Avatar
    Apr 2009
    Leeds
    Mileage : 56000
    I had mine into KwikFit a couple of weeks ago as it basically wasn't having any effect at all.
    Big difference afterwards - much cooler.
    But now the compressor is much noisier.
    I assumed that was a sign that it was actually working.
    2.8T Signum Design
    Regular Member Exclusive BV's Avatar
    West Midlands
    yeah mine aswell. whoosh whine silent...........whoosh whine etc...
    It cools not too bad when it's warmed up (you know what I mean )
    The thing is you can only hear the sounds inside the car, standing outside, the car sounds normal apart from the odd click from the relays when the comp kicks in
    Trim : GSi
    Mileage : 39k
    Bump.
    Now the weather is hot again the noise is back and I've had a thought. I get the quite common "chirp" sound from the AUX belt, more often when it's cooler & damp but it can happen any time.
    Now I know this can be related to a dodgy belt tensioner, so, my question is: does anyone else that has the same A/C whine as me also have the occasional chirp sound from their aux belt too?
    I've read on a couple of forums where this problem turned out to be worn bearings in the tensioner, when the a/c compressor kicks in the extra strain caused it to whine and there can be belt slippage at low rpm, maybe leading to the poor cooling when sat at idle.
    Does this sound plausible to anyone else?
    Regular Member mozzer99's Avatar
    bristol
    the other possibility is the aircon clutch is worn and slipping.
    this is replaceable without draining/evacuating the gas. Also the bearing inside the clutch is replaceable and when it's on the way out it will make a considerable noise (although it will do that all of the time as it is under load from the belt full time).
    jilava
    Quote Originally Posted by AntB View Post
    Bump.
    No I don't have this chirp sound from the aux belt, but I do have the whining sound inside the car. Goes away imidiately if I turn the aircon off. What's buggin me is last year it did not make these sounds but was topped up with coolant in spring so maybe now it needs regasing.
    Anyone tryed regasing? what was the result?
  1. Air Con Compressor
    By Siggy08 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2012, 15:52
  2. Air con compressor
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 28th November 2009, 19:20
  3. air compressor
    Last Post: 18th November 2009, 07:56
