Results 1 to 10 of 15
Thread: boost flat spot boost????
    woking
    Default boost flat spot boost????
    hi i have a cdti 150 i have read about flat spot problems on the site but they always seem to be on about 1000-2000k before turbo spools up but i have no problem at that point mine comes on full boost 1300rpm very strong then half a second flat spot at 2000rpm then boosts again all the way to red line so boost flat booooossssttttt any ideas i had the egr done about 1k ago....
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Sam it could be your boost sensor needing a clean
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    as above mate, if you have had a EGR replaced due to it being full of kak
    you can guarentee that the boost sensor will be caked up............
    woking
    how do i clean that is it an easy job
    woking
    found the how2 loks easy will try tomz as now have a crd-t to play with
    Regular Member pugs,signum's Avatar
    swansea
    Quote Originally Posted by lgtuk View Post
    nothing to it mate just under the engine cover middle back area at top of engine, just a bit of carb cleaner and a old toothbrush does the job quite nicely
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    has the swirl flap rod fallen off
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    I have this problem and the boost sensor is clean, is there anything else it could be? The egr, manifold and 3rd injector mod have been done, cheers.
    woking
    Quote Originally Posted by mattv6diesel View Post
    herd this being mentioned alot what is it were do u find it?
    swansea
    Take off the cover on the top of your engine, at the back of the engine block look down a gap at the air inlet manifold and you should see a rod that connects to 4 small pots, the pots are the swirl valves and if the rod has come off and there is dirty oily substance seeping out aroung the pots then the inlet manifold will need changing!
    I have given a linky below where you will find a picture of a rod that has fallen off in the forth post! hope this helps!
    http://www.vectra-c.com/forum/showth...ght=glow+plugs
  1. No Boost/Irregular Boost
    By Seery_SRI in forum Engine & Drivetrain
    Last Post: 8th March 2011, 08:48
  2. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
vectra c diesel flat spot
