Thread: wipers, water
    Regular Member vectra_'s Avatar
    australia
    Default wipers, water
    hi, when i flash some water to front secreen, the water goes straight up, it dosnt come straight into the secreenn how can i adjust that...
    Regular Member mikeeaston's Avatar
    widnes
    i use the smallest precision screwdriver in my screwdriver set that does the trick you just have to be a bit gentle
    WGAF#5
    either that or a sewing needle - this also helps give the direction/angle as you can see where the sprays going to go ... or a pin from a badge - just be very careful on how you do it
    Mileage : 000
    That is if you have the standard washer jets. If you have fitted the Insignia ones then you will need a special tool to adjust them.
  1. Wipers
    By LeeU in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2011, 09:28
  2. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  3. wipers
    By markf09 in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2010, 22:56
  4. Wipers
    By JSYSH466Y in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2009, 00:49
  5. wipers
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2008, 09:57
