Thread: Citroen HDi DPF
    Regular Member Boy Lard's Avatar
    Derby
    Default Citroen HDi DPF
    Short of joining a Citroen Forum, does anybody know if the 90bhp 1.6 HDi engine has a DPF? Car in question is a 2006 56 Berlingo.
    Thanks in anticipation
    WGAF#5
    yes they do - all the psa (citroen and Peugeot) hdi engines have the diesel particulate filters as they were the ones who designed the package
    dependant on age would determine wether its built into the exhaust or separate and if the additive tank is solid or a "camel Sack"
    and yes they too suffer with Egr Valve issues and a more common issue of the sump leaking closer to the gearbox end - it just needs removing and resealing correctly
    if you need any more info Pm me
    regards
    Dez
    Derby
    Cheers Dez.
    One more question then for now. Does it tell you when it needs regenerating? (ie blast up the motorway).
    WGAF#5
    no it doesent = it can go into forced regeneration when required even if you havent driven it very far - you may wonder why the engine fans are running full tilt for about 10 minutes ....its because it will be self regenerating
    Derby
    Cheers again Dez
  1. citroen
    By markj23 in forum The 'Off Topic' room
    Last Post: 1st May 2011, 14:59
  2. Citroen saxo vtr
    By vanquis1979 in forum Cars for sale
    Last Post: 15th November 2009, 00:02
  3. Citroen xsara
    By vectra-c1000 in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2008, 04:15
  4. Citroen C5
    By Triple Trouble in forum General Chat
    Last Post: 25th July 2008, 18:42
  5. Citroen 2cv
    By Jamie in forum Comedy & Humour
    Last Post: 17th July 2005, 12:42
