Results 1 to 10 of 15
Thread: Vacuum solonoid
    Regular Member suggs1971's Avatar
    east cleveland
    Default Vacuum solonoid
    Hi i own a veccy c 2.0 dti. On my veccy there are 2 vacuum solonoids, one at the front under the slam panel and one at the back next to the air flow meter. Right the one at the back is buzzing when the engine is running, the one at the front isnt. Just wondered if anyone with a 2.0 dti could check to see if there vacuum solonoid is buzzing as im sure when i had a veccy b i had this problem and the vacuum solonoid had failed as the veccy b went into limp mode at 3000 revs but my veccy c is ok at the moment just the buzzing from the solonoid. Cheers Andy.
    east cleveland
    Anybody had a chance to look at there veccy as ive sourced a 2nd hand vacuum sensor for £25.00 so before i buy it just wanting confirmation of if it should be buzzing constantly when engine running. Cheers for any help.
    Full Member Big Sig's Avatar
    east cleveland
    Cheers for the bump, hopefully someone will have a check on there dti.
    east cleveland
    Bump.
    Regular Member Innes's Avatar
    Plymouth
    Have you got the codes read yet? It may not be putting the spanner light on etc but it may still pick something up. I have a vacuum solinoid problem. It comes up on the code reader without even running the engine. Heres the thread I started:
    http://www.vectra-c.com/forum/showthread.php?t=107825
    Just trying to find the part number so I can source a replacement part.
    east cleveland
    Yeah had my veccy on my mates opcom and no fault codes, the buzzing noise did seem louder today, definatly coming from the vacuum sensor/solenoid, tried a screwdriver next to it and listened, no buzzing at all from the front vacuum sensor. Part number i got for the vacuum sensor at the back on mine is 9158200.
    east cleveland
    Bump. Need some advice as buying the part tomorrow. Cheers
    east cleveland
    Well ive put off getting the part as ive had 2 different pieces of advice. A neighbour whos a mechanic says the vacuum sensor is on its way out when it starts buzzing constantly, another mechanic says it should buzz constantly. When i got home from work tonight i popped the bonnet, there is definatly no buzzing from the front vacuum sensor when engine running, just buzzes for 2 to 3 seconds when engine switched off. The vacuum sensor near the air flow meter when the engine is switched off will stop buzzing, the front one will buzz for 2 to 3 seconds and then the rear one will for 2 to 3 seconds.
    If any kind person with a 2.0 dti or 2.2 dti (i think they are similar) could pop there bonnet and check the vacuum sensors when the car is running, this would be a big help.
    Cheers Andy.
    East Midlands
    Quote Originally Posted by suggs1971 View Post
    Cheers Andy.
    Hang on a minute m8,i'll try mine see if it makes a noise.
  1. Vacuum Solonoid
    By holtie in forum Engine & Drivetrain
    Last Post: 17th January 2013, 22:11
  2. oil vacuum
    By Al 22 dti in forum The 'Off Topic' room
    Last Post: 16th February 2012, 12:12
  3. AFR & vacuum gauge 3.2
    By TimTay in forum Styling
    Last Post: 14th November 2011, 01:40
  4. vacuum
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 17:59
  5. vacuum pump
    By Dougb in forum Engine & Drivetrain
    Last Post: 30th June 2010, 22:41
