Thread: Diesel priming bulb / pump dti
    dudley
    Default Diesel priming bulb / pump dti
    Just been to the carshop and bought an inline diesel priming bulb, like what you find on other makes, Rover diesels for example, however my experience of other makes is that their priming bulbs are fitted before the filter and used to provide pressure to the fuel system and fill up the filter,
    don't think it will work that way on the DTi for some reason, or it would have one fitted as standard,
    I know that the recommended sealey pump needs to go on the return to the tank, so it basically pulls the fuel around the system and dumps it back into the tank, but it is not designed to be left in place all the time,
    I want to leave it in place all the time, I do not use my car every day, and it can sometimes be left for a few days without being started, it has the fuel draining back into the tank problem, I have changed the injector leak off pipes but it hasn't done the trick, I haven't the funds for the injector seals to be changed just yet, and do not want to scrap my pump by priming it with the key, whcih I am currently doing,
    Has anyone fitted a retro priming bulb to the DTi, where did you put it to get the best result and have you any pics of it fitted,
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    When you did the leakoff pipes did you replace the t joints ? Not sure about the priming pump but someone else might have an opinion
    Irmscher Insignia CDTI 130
    dudley
    Quote Originally Posted by bigmac View Post
    no didn't change the t peices, shop didn't have any to fit, didn't go to stealers, I have had to use braided fuel pipe as they didn't have the all rubber pipe one small enough, didn't cost a lot only a fiver,
    do vauxhall sell the t pieces and the pipe in a set, or can the pieces be bought on their own, or has anyone got an ebay link to t pieces that will do....?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    T joints can be bought from vx and this could be your problem as they crack letting in air
    dudley
    T joints can be bought from vx and this could be your problem as the crack letting in air
    fingers crossed didn't know they could crack, will call stealers in the morning,
    any ideas on the priming bulb anyone, I will need to put it some where to prime the system when I have taken the t-pieces off.
    Regular Member rec's Avatar
    Jan 2010
    Bradford
    did you change the long pipe that runs up from the pump mate? or just the 4 pipes into the Ts? i recently did mine on my vec B DTI and didnt change the long one, changed that and it now starts fine
    dudley
    Quote Originally Posted by rec View Post
    I didn't , have ordered some new black silcon 4mm hose off ebay to do them all again, the hose is 4mm i.d, and the t pieces i've seen are 4 mm also,
    would any one recommed using the 5 mm t's, instead of the 4mm t's, to get a snugger fit on the pipe,
    Jan 2010
    Bradford
    Quote Originally Posted by olid2002 View Post
    it will be the pipe from the pump mate, i made the same error, swapped it over and et voila
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Easy mistake to make
  1. Diesel pump
    By ads3 in forum Engine & Drivetrain
    Last Post: 9th June 2011, 18:57
  2. Diesel pump???
    By pasty steve in forum Engine & Drivetrain
    Last Post: 15th September 2010, 15:34
  3. Diesel Pump?
    By jrpatten in forum Engine & Drivetrain
    Last Post: 14th February 2009, 21:47
  4. Need me a diesel pump!!!
    By cov in forum Engine & Drivetrain
    Last Post: 20th January 2009, 18:42
  5. diesel pump!
    By littlesxi in forum Diesel Engine related
    Last Post: 29th January 2008, 01:15
