Results 1 to 3 of 3
Thread: VXR Gear lever
    Sodding Typical on Sea
    Default VXR Gear lever
    So what is the choice does the Astra one fit and the cradle bolt in? or is it vectra only hence bloomin expensive, but the standard one is no delight to hold and use.
    argyll, scotland
    astra one will fit no problems apart from you havr to change the plastic over that holds the gaiter in
    at the end of the shaft there is a metal ball joint just gently twist your old one out and pop the vxr one in its a bit fiddly but a great upgrade
    Agreed looks the mutt's I will be avin' some a that then
  1. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  2. How to change gear lever
    By hairy31 in forum Styling
    Last Post: 27th December 2009, 20:28
  3. gear lever surround
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2009, 09:43
