Thread: any clutch experts on ere that can help me?
    rotherham
    Angry any clutch experts on ere that can help me?
    Ive got a 52 plate vectra saloon, 1.8 ls and im having trouble with the clutch, im new to the vectra c and dont know much about them part from theyre the most comfy car ive ever drove. cheers craig
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    Whats the problem with the clutch? they do suffer from judder on take-off but they released a revised/modified clutch assembly to cure this
    rotherham
    thanx for replying mate, im having problems with the clutch pedal. It will select gear as it should but sometimes it only comes back up halfway. Ive checked the fluid level and its ok also checked for fluid leaks and there was none to be found, any ideas? Its a 1.8 52 plate saloon, cheers craig
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    checked the clutch return spring?
    rotherham
    ok will check it mate, will i be able to get one from the main vx dealer and how much roughly would it be?
    11 Post(s)
    You might get more responses if you asked in the appropriate area of the forum (Engine & Drivetrain) where more visiting traffic will probably be looking. This one is really just a say hello area.
    Hopefully a mod will move it over for you.
    Welcome, btw.
    WGAF#5
    moved post to assist on people helping you better
    as above could be the clutch return spring as these are known to go weak
    or it could be the clutch slave or master cylinder starting to go as well
    Reading
    Just been down to dealer to buy a spring, cost £10. Will fit tonight. Some good instructions on here as to how to fit.
    rotherham
    ok thanx, drove the car today and the pedal behaved as normal pedals do
  1. a bit of help from the experts:)
    By macs_silviu in forum Bodywork & Interior
    Last Post: 9th July 2012, 22:41
  2. Any physics experts???
    By CDTi Mike in forum The 'Off Topic' room
    Last Post: 23rd August 2011, 20:52
  3. Looking for experts
    By Rebellion8878 in forum South Central (ARO - matty2fatty)
    Last Post: 4th March 2011, 12:47
  4. Ice help, any alpine experts?
    By Keithy in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2010, 22:35
  5. any clutch experts ere?
    By vectra08101981 in forum Engine & Drivetrain
    Last Post: 3rd June 2010, 11:18
