Thread: How To Remove Glovebox?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    Default How To Remove Glovebox?
    hey folks, im doing the cooled glovebox mod, but i can't find the picture with all the screw locations on?
    PaZ!
    Regular Member Innes's Avatar
    Plymouth
    There should be 3 screws along the top (when glove box opened). They usually have black square caps over them. Just pop them off and there are your screws. There are then 2 more at the bottom on the under- side of the glove box. They are slighlty sunkien but you'll see the holes. Its really simple to take it off. Done it loads of times. Hope this helps
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    2 underneath the hinge and 3 along the top, you may have to remove the long dash plastic strip to access then. Lower it down and disconnect the wire to the glove box light and bobs your uncle.
    EDIT: Beaten by a fresher .
    Plymouth
    I'd recommend prising the glove box light fitting out first and them disconnect the plug otherwise you'll have your hands full holding the glove box and trying to disconnect the lights plug. Sorry Rushy, i'm just a little bit faster typing lol!
    Regular Member Ollie's Avatar
    Jan 2010
    Towcester
    Engine : 1.9 CDTi (150)
    Mileage : 126000
  1. How to remove the glovebox?
    By the1theycallthe1 in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2012, 22:19
  2. Glovebox
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 01:09
  3. Air con in glovebox
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2007, 06:13
vectra c glove box removal
vauxhall vectra glove box removal
remove glove box vectra c
how to remove glove box vauxhall vectra
removing vectra c glove box
how to remove vectra c glove box
opel vectra c glove box removalremove vauxhall vivaro glove box trayHow to rem o ve vauxhall vectra glove boxhow to remove a vectra glove boxtaking off vectra c glove boxhow to take out a glove box on a vectra cremoval of glove Bix in vauxhall mokkahow to take out glove box 2005 vectratool to open glovebox vectraopel signum glove removalhow to.take glove box out of a 08 vectraglovebox vectra cremove vectra glove boxvauxhall vectra 2008 glove box removalhow to remove glove box vectravectra glove box removalwww.vectra-c.comremoving glove box on vauxhall signumhow to re move glove box vectra c
