Thread: Engine Tempreture Guage Issue!
    Skelmersdale
    Default Engine Tempreture Guage Issue!
    Hi all,
    Got an issue with my 1.8vvt vectra. The tempreture guage is not reading hot when it should. The most it goes up to is to just above zero. When i turn the fans on they are blowing hot but not as hot as they should be.
    However when i turn the engine off and back on to the ignition lights the tempreture guage reads as normal i.e. 90. I have also noticed at this point that the light with the car and the spanner stays illuminated untill I turn the engine on, at this point it goes off.
    Any help with this much appreciated, thanks.
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Coolant Temperature Sensor. Had similar issue on my VVT and this was cured by fitting a replacement.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Sounds very much like a faulty connection "somewhere". A big somewhere!!! I suggest that you raise the bonnet and disconnect and re-connect all the connector blocks that are both visible and "invisible". That includes the large ones by the ABS block and all of the small ones as the fault could be anywhere. Good luck!!!
    LEDBURY
    sounds like thermostat i changed mine because of this problem , the whole housing sorted this out.
    happy days, how long ?
    Skelmersdale
    Cheers guys. The tempreture guage seems to remain at zero during motorway speeds, when town driving however the tempreture guage will rise to 80-90 ish. How much did you pay for a thermostat mate? Easy to do yourself?
    May not be related but I have just had me air-con regassed, initially was cold but now only blowing slightly cold?? A leak possibly??
    Regular Member Exclusive BV's Avatar
    West Midlands
    My VVt 1.8 does exactly the same, Mostly the temp gauge reads zero when driving but When the aircon is on, it goes up slightly. When I pull up to the house and sit there for a bit, it also goes up to about 1/4 (sorry did'nt look at the number) and goes no further regardless of how long i sit there.
    I was not overly worried about this as my old astra was very similar.
    Some of you guys reckon it's a faulty thermostat and the same thing had crossed my mind too.
    Are there any 1.8 VVT owners out there whose temp guage works differently from this ?
    edit: I tried the BC thing from the secrets thread which give you some engine data on the Radio display but did'nt work on mine. I remember that gave you the engine temp. Does this reading come from the same source??
  1. I have got a very serious issue. 150bhp engine.
    By 123rado in forum Engine & Drivetrain
    Last Post: 8th September 2012, 18:47
  2. Engine Tempreture Issue (z18xer engine)
    By SteB13 in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 18:56
  3. Engine Tempreture Issue
    Last Post: 17th January 2011, 19:30
  4. Strange engine light issue
    By raddish in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2010, 23:42
  5. outside tempreture stopped working on the car
    By kamar in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2010, 21:23
