Thread: DTI Glowplug Change
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default DTI Glowplug Change
    Chaps,
    My 2.2DTi has in the last week struggled more and more to start, it just simply cranks over longer before firing, I'm hoping it NOT an air leak issue as the tank is full and I only ever park facing downhill (it has that issues uphill overnight).
    So anyway, I'm gonna change the glowplugs first as they look easy to get too. When's the service interval change for glowplugs? I remember on the older Izusu/Vauxhall lumps it was 70,000miles, I've had this since 84k and it's now got 105k on it.
    Si
    Regular Member Dazzy2006's Avatar
    Notts
    would your engine be actually using the glowplugs to start, i also have the 2.2dti and mine dont light up at all at the minute but it starts fine?
    West
    I very much doubt it's the glow plugs at this time of year... most likely leak off pipes/air leak or slight drop in compression
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    yep i need a glow plug changing , but reading across the forums i believe its a pig of a job as they can easilly cross thread and bits can fall into the chambers,
    Aldermaston (Berks)
    They dont cross thread m8, they like to snap off in the head, i know i have one stuck in there at the moment & it can stay there.
    West
    I've always replaced my own plugs... not dificult, just pre soak the old ones & take care putting the new ones in.
    Apr 2009
    Stevenage, Herts
    Yeah I didn't believe that the engine starts without using the glowplugs unless really cold (like 5deg C or lower), but it seems it does.
    I'm gonna try the leak off pipes first - I bought the kit last year but it was so tight getting the old pipes off I gave up thinking I'd never get the new ones on! But this time I'm gonna go for it!!!
    I'm still toying about changing the radiator myself as it's leaking - just looks like a pig of a job, I've asked on here about it but no one replied, so guessing know one's attempted it...
    Regular Member DaveW555's Avatar
    Cannock
    Diesels dont really need the glow plugs unless its really cold, they'll start on compression alone, the rad should be easy enough to change, just be careful with the ac rad and the bumper has to come off but apart from that there's nothing too tricky.
  1. no glowplug light, why???
    By frasedeb in forum Engine & Drivetrain
    Last Post: 22nd January 2013, 23:05
  2. Glowplug switch
    By matt_harw in forum Engine & Drivetrain
    Last Post: 9th October 2011, 13:02
  3. Egr & glowplug issues
    By VECTRA HEAD in forum Engine & Drivetrain
    Last Post: 6th October 2011, 20:59
  4. glowplug light
    By clyde in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2011, 00:39
  5. glowplug light
    By bob4 in forum Troubleshooting
    Last Post: 12th October 2009, 20:52
vauxhall vectra glow plug change interval
vauxhall vectra 2.2 dti glow plug replacement
