Thread: warning light not going out
    Jan 2010
    cumbernauld
    confused warning light not going out
    hey guys, wondering if anyone can help me. nothing to serious i hope but il try explain the best i can... when a sensor picks up that theres a light out or whatever it tells you on the screen in the centre consol and on a wee sqaure light on the speedo, you press the button on the right hand stock at the steering wheel and it goes away. well the wee square light on my speedo is staying lit. its a wee pic of a lightbulb with an exclamation mark in it, most importantly is that the symbol for a light being out? and can that symbol ever be anything more serious. and second since all my lights are working is there a reason for the centre consol going back to normal and the speedo keeping telling me? cant find all the symbols and meanings in my handbook that would also be a handy thing to have if anyone knows where to get a list. hope someone can shine some light thanks guys.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    You've most likely got a bulb that is on it's way out, or possibly loose/dirty connections to that bulb. Does your centre display tell you which bulb it thinks has failed? If so check/clean or change that particular bulb and you should be sorted
    Winchester
    Quote Originally Posted by peterAC View Post
    btw - love this pun !!!
    11 Post(s)
    Check your brake lights. Should the upper tail/brake light fail, the lower tail light takes over the role of tail/brake light.
    S.Shields (Newcastle)
    Its a warning telling you that the bulb is near the end of its life! Ive got a front left fog lamp out and, i checked it for about a week and it still worked even tho the computer said it didnt then it went off! :-( sooo I guess its on its way!
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by neil3734 View Post
    That's about it...as simple as that!!
    The driver info centre will normally warn first, in "panic mode", almost like a smoke alarm!
    However if the bulb warning has come in the rev counter than a bulb is near to or has failed
    The usual ones are brake bulbs, the system swaps over and uses the rear marker lights
    The only way to check is to look at them when in use
    The rear indicator bulbs are also quite sensitive, therefore if you replace one replace the other
    Jan 2010
    cumbernauld
    thanks guys. il try cleaning them 'cause they all work just now. its a pain though, the front parking light and something else that i forgot and obviously the brake light come up every time i start the car or change gear or look at the mirrors or do anything realy. wish they werent so sensitive. thanks alot though
    Jan 2010
    cumbernauld
    Quote Originally Posted by LJ sxi-nav View Post
    didnt mean it lol, your comment gave me a wee giggle though cheers.lol
    11 Post(s)
    Is this the handbrake light - it also doubles up as the low brake & clutch fluid warning light. Best check your fluid level if this is coming on while driving the car.
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
why is the warning light not coming for ice warning
