Thread: front fog lamp question
    Aberdeen
    Default front fog lamp question
    Is it normal for the front fogs on a face lift sri to wobble?
    My ones seem to be secured at the bottom ok but the top seems loose
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Not sure if this will help you, but this is how they are fitted to an XP2/VXR, so I imagine they may be similar.........
    Aberdeen
    From what I could see from below no it didn't look like that.
    On my one it doesn't have that plastic around the back, I can get my hand up and grab the hole light unit.
    It feels like it should maybe clip in at the top?
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    One bracket at the top, two at the bottom.
    Sounds like your top one has let go. You may be able to weld it with a soldering iron - I did. Easier to get at / remove the light with the bumper off
    Aberdeen
    cheers, will take the bumper off and have a proper look then
    Mine is held onto the bumper with 3 bolts. Two at the top, and one at the bottom. I can just about reach the bolts on mine (2.2 Elite) with a flexible shaft between an 8mm socket (I think that's the size) and rachet with the bumper still in place.
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Hmmm - maybe I got the top / bottom ratio mixed up, but it's definately 3 bolts, and far, far easier to pull the bumper - I've done it both ways.
    It might be one on top, and two down the bottom. Can't remember. Long time ago since I tightened them up because they were both loose.
  1. Engine management lamp - Question
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2012, 20:48
  2. front fog lamp
    By bryan_jackson in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2010, 17:03
  3. Signum Front Fog Lamp
    By Smudger1 in forum Electrical & ICE (including SatNav)
    Last Post: 6th November 2008, 13:53
  4. Front Fog Lamp VAUXHALL VECTRA 2006
    By spennny in forum Bodywork & Interior
    Last Post: 3rd November 2008, 13:59
