Results 1 to 3 of 3
Thread: EGR Valve
    Hull
    Default EGR Valve
    My Car has been running like ****e for the past couple of months at low revs so I thought I would have a go at cleaning out the EGR before replacing it.
    The problem was with one of the Allen key bolts rounded off.
    I can force it off, but before I do, does anyone know where I can get replacement bolts from.
    Are they something that I can pick up from a local motor shop, or do they have to be ordered from Vauxhall.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    try a local motor shop or engineering firm if that fails it will have to be the stealers
    Mar 2007
    GB
    i dropped a bolt on my CDTI150 while changing egr, fell on the plastic undertray no way to get at it
    went to local hardware store, and they got me another bolt exactly the same within 2 minutes. it wasn't the allen key type in my case, but i'm sure a good hardware store will be able to match whatever your looking for.
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Troubleshooting
    Last Post: 6th July 2007, 00:43
