Thread: Bonnet wont open on 53 plate vectra C
    Workington
    Default Bonnet wont open on 53 plate vectra C
    Cant get the bonnet to pop at all, have butchered the grille, still no luck.
    It appears to have plastic 'cowls' behind the grill and possibly one covering the spring for the bonnet release.
    I am pretty sure the cable has become detached as I can hear it making noise by the passenger side headlight.
    Any help on how to get the bonnet open would be much appreciated.
    I have read the other posts on stuck bonnets but none seem to cover my car.
    Regular Member booker413's Avatar
    West sussex
    hi mate, i had the same, get someone to pull the bonnet while you pull the leaver, the problem is the locating post, just grease it up . and all should be ok..
    best of luck mate
    adam
    Workington
    I dont think pulling the lever will work as it appears to be disconnected under the bonnet. The cable on the lever is about 2 feet too long when you pull on it.
    I think I need to get at the spring under the bonnet but cant seem to find a way to do this.
    Workington
    Anyone ???
    Really getting stumped by this
    kent
    can you unclip the lever so you can get to the end of the wire cable
    itself, then pull with a pair of pliers (hopefully it hasent become disconnected)
    if no luck i can ask my pal who is a vauxhall mechanic.
    hope this helps
    Workington
    I have disconnected the wire from the lever in the car, pulled with some plyers, but no joy.
    Also the cable seems to be making noise around the passenger side head light, so I think it is disconnected under the bonnet from the release.
    Just cant seem to find anyway to get my hand near the spring under the bonnet, or see anything when looking through the bonnet where the grille used to be!
    kent
    try a search on this forum for bonnet release, some good advice is to be found!
    lots of pics which helps.
    May 2008
    Derbyshire (south)
    Regular Member cbl1985's Avatar
    warrington cheshire
    you have to take the botton grill off and get ur hand up and move the catch it happend to me last week
    Workington
    Thanks for all the replies, will have a go this weekend
  1. Bonnet wont open
    By hairymark in forum Bodywork & Interior
    Last Post: 20th December 2012, 03:10
  2. Help!bonnet wont open!
    By dazza2393 in forum Bodywork & Interior
    Last Post: 2nd January 2012, 15:28
  3. Bonnet wont open
    By boodoo warrior in forum Bodywork & Interior
    Last Post: 14th August 2011, 14:55
  4. Bonnet wont open
    By Apone in forum Bodywork & Interior
    Last Post: 17th September 2009, 00:03
  5. Bonnet wont open
    By Johnytuono in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2006, 13:30
