Results 1 to 10 of 16
Thread: Help needed - V6 CDTi problem... Still
    Regular Member V6Andy's Avatar
    Plymouth sometimes Oxford other times
    Default Help needed - V6 CDTi problem... Still
    Hi all,
    A while ago I put up a post about my facelift Vectra 3.0 V6 CDTi having a intermitant problem pulling when it hits about 2,000 rpm and is like a rocket after 3,500 rpm as normal.
    Well most of you guys came up with the suction control valve fault and very kindly gave me the job code aswell.
    I proceeded to my local stealer with code in hand to which their reply was "never heard of it"!
    So I explaind in lamens terms the problem, head mechanic came out, even he had never heard of a suction control valve! But would look in to it for me...... never to be heard of again!
    Anyway weeks have passed and I am now sat sweating my ass off in Afghanistan, the wife takes the car to the vauxhall garage to get it sorted for my return, 2 weeks have now passed, they had to download special software apparently, and played with the ECU
    Needless to say they have knackered it right up and wont even start now, they have quoted me £1700 for the ECU and wont pay a peny towards it, even though it was their fault.
    What can I do, does anybody have any advice or contacts?
    I really dont know what to do!
    Contact Vauxhall
    Ask for the area technician to attend your vehicle
    He should know about the blocked Suction Control Valves
    Field Remedy 1957
    It is on TIS
    I can try and get you the part number on Friday (it's on my service history)
    Take that to the parts department, then go to the service department
    edit :
    search "field remedy 1957", it's well documented here now
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Suction Control Valves kit: Part number 98086740 or 8 19 348
    Quote Originally Posted by Celes View Post
    Cool cheers, but what do I do about Vauxhall and my ECU?
    Regular Member Innes's Avatar
    Plymouth
    Tell them they are a bunch of useless muppets and cough up... or else.
    Quote Originally Posted by V6Andy View Post
    If the car is under warranty the repair was approved by Sureguard (Retailer Warranties Limited)
    Contact them and advise them that the diagnosis from the dealership was incorrect and unnecessary
    Equally, if the ECU is replaced and the fault is still present simply go back to the garage, "What now?"
    warranty?
    I wish, wouldn't be worrying if I has one of them!
    The Field Remedy includes an update to the EMS
    I would suggest you make an appointment to discuss the matter with their Service Manager
    Were you given a receipt for the work, if so what exactly does it state?
    If the EMS was updated they pretty much wasted their time as it only works with the uprated SCVs
    The original SCV will return an unknown fault code, and I assume it is this they have diagnosed hence the update they performed
    However, with so many ECU around the car, would need know which one they played with
    There are three on the engine alone
    If they killed it they should pay for it!
    My House
    Hi,
    What were they trying to do? Was it something they had said they would be trying or something they did off of their own back?
    The reason i say this is if the dealer has said it could bork the ecu sir but at your request we will try but there are no guarantees's kind of thing then your case is a little less sure.
    However if they have borked the ecu without telling you they were going down that route of if there was a corruption of the calibration this is the dealers problem.
    working in a dealership you can imagine we see a fair share of issues that arent the fault of the tech or the car but sometimes just happen.This doesnt mean the the car can be given back to you in a worse state than when you gave it to them.
    If it is something they have cocked up or something that has gone wrong whilst in the dealers care it is their responsibility to sort it.
    By the way i would be very interested to know exactly what software they had to download!!!
  1. Cim modue problem cim DL needed or another that will fit???
    By big rich in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2011, 14:41
  2. 1.9 cdti major problem help needed
    By baztheman in forum Engine & Drivetrain
    Last Post: 6th September 2008, 19:58
  3. Coasting rpm problem - help needed please
    By Vid in forum Engine & Drivetrain
    Last Post: 29th May 2008, 08:27
  4. Overfuelling Problem Help Needed please
    By rickyroo in forum Engine & Drivetrain
    Last Post: 30th April 2007, 21:55
  5. immobiliser/key problem, HELP NEEDED!!!
    By kgsric in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2006, 20:16
v6 cdti suction control valve
