Thread: Short air intake
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    Default Short air intake
    Can somebody please supply part number for the short air intake.Want to change mine as it runs all the way along car behind hot radiator.Believe it is the 1 used on the 2.8 and v6.Was a thread on here once showing differences.
    Regular Member Marcosuk's Avatar
    Fife
    The short intake off the 2.0t is 9177099 & the wee bit to the airbox is 9177104.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Keep your long one mate, its tuned for the engine. Been down this path on the 2.2 and it has a negative affect, the only benefit is slightly less heat soak when sat at the lights.
    Regular Member LEEROB695's Avatar
    scunthorpe
    when you say it has the negative effect can you ellaborate a little
    thanks
    Vehicle : SRi
    Mileage : 137000
    It affected low down torque. An NA works by vacuum, it sucks air into the cylinders rather than forced like a turbo. Each time a piston gets to the bottom of its stroke and the inlet valve closes then its going to sent a pulse down the intake system. The length of the pipe is tuned to accommodate this pulse for each engine, the 2.2 obviously needs the longer intake, and to back this up all the NA VX220 boys keep the long pipe as they all notice a drop in torque with a shorter pipe. To put it another way, why would VX fit a longer and more expensive pipe when they could fit a shorter and cheaper one. TBH on a 140-150bhp Vec C you probably wouldn't notice the difference anyway, same power in a little shoe box shows up quite a bit. For raw top end BHP the shorter one may well add a little but to the detriment of low down torque and as the saying goes, "Torque wins races and BHP sells cars" or something like that LOL
  1. Cut short
    By Big Dave in forum Comedy & Humour
    Last Post: 17th April 2012, 13:31
  2. Best oil for short journeys???
    By ridgers84 in forum Detailing and Car Care Discussion
    Last Post: 30th March 2012, 21:10
  3. A few short ones
    By bobssignum in forum Comedy & Humour
    Last Post: 4th October 2011, 18:59
  4. Short Aerial
    By DeeBe in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2011, 19:44
  5. Just a short vid
    By EliteSingh in forum Electrical & ICE (including SatNav)
    Last Post: 8th August 2011, 10:16
