Results 1 to 10 of 13
Thread: Huming Noise
    Newcastle upon Tyne
    Default Huming Noise
    Hi new to this forum and was advised to give it ago by a friend so hope you guys can help.
    I have 53 reg Vectra 2.0DTI. The vehicle had a huming noise which seems to come from the front of the car. It starts at around 30mph and gets louder and then at about 50mph seems alot quieter. It also gets a lot worse when turning left for some reason and you can feel it through the pedals.
    I have checked under the car and found that the wishbone needed replacing so did that yesterday. I have also put new tyres on the back and moved the back to the front but still no joy.
    I am thinking wheel bearings or hub assembley but what side would it be if the noise gets worse turning left.
    Hope someone can help
    Michael
    south wales
    jack the car so that the wheel is off the floor than try to rock from side to side and then up and down if there is any movement check your nuts are tight and if it still wobbles it defo your wheel bearing
    hope that helps
    it does sound like a bearing
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Does definatly sound like the a wheel bearing is on it's way out, jack the wheel up and spin it listening carfully. If there is a gritty noise or it's just not smooth to turn it's knackered. There isn't alway play in them when they start making the noise
    Newcastle upon Tyne
    Hi thanks for the reply and I will have a look at it this week. I have been looking on ebay for a hub/bearing firstly can anyone recommend a make and secondly what is IDS. I have a little car skidding warning light on my dash that comes on when I am on a icy road is that it
    Michael
    Jan 2010
    glasgow
    what age is the car? is it a face lift i think any 1 after o5 /06 is ids but u can tell with ur chasi number
    Newcastle upon Tyne
    Its a 2003 2.0 DTI LS
    ireland
    i got same sorta noise,ive an 05 cdti huming from front,i emailed a bloke on ebay vauxcentre, he checked out my reg and chassis number and informs me i have the bearing with ids,woopey do twice the price lol,i cant honestly see what ids does as my wifes old 1.4 puma with its prehistoric suspention wipps the crap out the vecy for cornering,in my opion is just more crap go wrong ,which it has lol.
    if u want link for the bearing bloke just ask
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Pretty sure IDS was only fitted with the sport button. You would know by looking at the front struts
    ireland
    hi john,do vectra have the sport button i thought that was only astras,the sport button activates cdc .continous damping control
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    After doing a bit of research the Vec can have IDS without having the sport button (and yes some Vec Cs/Signums came fitted with the sport button)
    You'd be able to tell if you have IDS by looking at the strut though. If it looks like a normal strut with no extra wires then you don't have IDS. If you have a little tank and a few wires going to it you'll have IDS
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. M G ZR Noise
    By crispy007 in forum General Motoring Chat
    Last Post: 17th December 2011, 12:03
  3. Air con noise?..
    By bigdave1701 in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2011, 18:14
  4. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
