Thread: cd30
    kirriemuir
    Default cd30
    hi can i turn off the display on my cd30 from computer readings to just the date and time like it go,s when i put the key in. hav,nt got a manual for it
    Full Member Robsey's Avatar
    North East Cheshire
    16 Post(s)
    Trim : Energy
    Mileage : 131,000
    I assume, that you have either a BID (board Info Display) or a GID (Graphic Info Display), as the TID (triple Info display) with clock buttons on the bezel will nit have BC capability.
    The only way to do this is via Tech 2 programming, in which case you would have to have your BC functions disabled.(Changing of the code index number).
    This would however mean that you would only get the stop watch function on your BC menu / screen.
    kirriemuir
    i,ll leave it then i thought i could maybe just leave it on date time instead of seeing bc all the time, its making me watch everytime i put the foot down at the useage
    North East Cheshire
    16 Post(s)
    Trim : Energy
    Mileage : 131,000
    I assume that you mean, when the key is in but you've turned the radio off.
    The only way to do this, is to cut power to the head unit only, but keep the power fed to the screen.
    If you disable the headunit (as if the radio had been removed), then the display will show time and date and temperature only.
    You could put a switch into the red feed wire to the radio head unit to achieve this. note that the radio is fusd at 15 amps, so the switch will need to be rated at this value, or alternatively use a relay to do the switching operation.
    North East Cheshire
    16 Post(s)
    Trim : Energy
    Mileage : 131,000
    Just tried it in mine (Unplugged the head-unit with ignition on).
    Sorry but the BC functions were displayed...so it is a tech 2 thing I'm affraid
    kirriemuir
    thats a pity my wife says i,m obsesed with mpg,s
  1. Fitting Parrot MKi9200- Can it run through CD30 aux?(does CD30 even have aux!?)
    By dibble750 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2013, 02:20
  2. Quick CD30 to CD30 MP3 question
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2012, 00:47
  3. Cd30 & bid
    By KyleSxi in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 15:50
  4. CD30 to CD30 MP3 Conversion
    By yysnet in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 00:20
  5. Replacing CD30 with CD30 MP3
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2007, 13:38
