Results 1 to 3 of 3
Thread: Saloon boot lid only opening with key fob?
    Regular Member spida_singh's Avatar
    UK, Leicester
    Default Saloon boot lid only opening with key fob?
    As above
    No matter what, i can't manually open the boot lid when pressing underneath the Vauxhall badge. I have to turn the car off, remove the key and press the boot lid button on the key fob to open my boot?!?!
    Not had a chance to check the manual. But i know I have not changed anything. Just wanted to make sure i was not missing something.
    It's been like this for a few days now.
    Any ideas before I go back to Vauxhall's?
    Regards
    Regular Member wise1's Avatar
    Jan 2010
    essex
    so are you trying to open the boot with the engine running? if you are you might find its a security safe guard to stop someone opening the boot when you are at a set of traffic lights??
    I will check mine later to see....
    UK, Leicester
    Quote Originally Posted by wise1 View Post
    Sorry, i should have been a bit clearer.
    No matter what state the car is in. I can't manually open the boot lid. I know there is a safety feature which doesnt let you open the boot at all with the ignition on, as well as with the car being on if trying to use the key fob.
    I used to be able to open the boot manually with the car running during cool down after my commute to work.
    Now, I must turn it off as it only opens using the key fob, and not the boot lid button.
  1. siggy boot not opening
    By dahmich in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2013, 06:12
  2. Vectra c boot not opening
    By shug176 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th August 2012, 10:27
  3. Boot Lid Opening on Estate
    By Ben R in forum Bodywork & Interior
    Last Post: 9th August 2011, 19:26
  4. Boot lock not opening
    By Johnsdutton in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2011, 10:09
  5. Boot Opening
    By dc6839 in forum Bodywork & Interior
    Last Post: 26th January 2011, 20:46
insignia boot lock will only open from key fob
My open Insignia boot only opens with the key
insignia tailgate opens only with remote key
vecyra c boot willonly open with key
insignia boot opens using the key fob only
