Results 1 to 10 of 17
Thread: Is this right ?
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Is this right ?
    Trying to get a part for my vectra need just the front pipe from the engine to the cat the one with the felxi bit on please see below can someone tell me if this is right
    http://www.onlineautomotive.co.uk/Pr...egoryID=114060
    http://www.onlineautomotive.co.uk/Pr...ges/301855.jpg
    P.S has my car got a dpf I think that's right 55 reg 8v vectra c
    Regular Member crespo's Avatar
    Bournemouth
    Dont know if that part is corect but if your flexi pipe is split just get a new flexi part welded on for between £40 and £60, It is much cheaper.
    Just phoned vx they said no DPF on my car also so it only comes with the cat at over £345
    Anyone
    Quote Originally Posted by crespo View Post
    Thanks m8
    were can I get one of the flexi part from?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Go to a custom exhaust place (like Powerflow) and get them to replace it, be about £60-£80 I would imagine.
    Bournemouth
    What exactly is wrong with your exhaust. You would be amazed what a performane exhaust centre can do with what you already have. If there is a pipe blowing they can replace it (no need to replace the cat if it is ok) or as i have stated already they can replace the flexi section as well if that is blowing.
    It's just the flexi bit is split that all went to quick fit they said need a new one which only comes with the cat as have VX to
    Bournemouth
    What he said. Google powerflow exhausts and then find your local supplier on there site and take your car down. It will take no more than half an hour to fit.
    And also be a loads cheaper.
    Bournemouth
    Quote Originally Posted by vectra 120 View Post
    They would say that as they dont repair systems. And also there is not enough £££££ in it for them to do it.
    I had the flexi section cut out and replaced on my old 156 at a powerflow centre. It cost £65.
    It was still going strong when i sold it 2 yrs later.
    Just phoned powerflow they want £120 and it's a two week wait
