Results 1 to 10 of 28
Thread: 1.9 cdti spanner light power loss
    southampton
    Default 1.9 cdti spanner light power loss
    hi, literally purchased this car from a dealer yesterday... it's a 54 plate vectra cdti 150bhp with 47k on the clock.
    Question one. are they all sluggish below 2200-2500rpm?
    Question two. was driving it today and was the first time i had it up to temperature, when i gave it a bit of welly to see how it went. Sluggish below the 2200rpm mark, but seemed to pick up nicely after, then hit around the 4000rpm and the spanner light turned on and i lost all power. Felt like the turbo had stopped spinning, or maybe it had gone into a limp mode?
    I then crept to my destination where i was parked for half hour moaning about it. Decided to drive it home, and when i turned the ignition on, the light was off.
    Drove it, seemed fine.... got it up to temp again and gave it a bit of stick and was fine.
    Any ideas on what trouble i may have just bought?!!
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Sounds like a split hose bud but the best way is to get the codes read.
    Under 2200rpm points to the EGR valve.
    Like I say bud the best bet is to get the codes read.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    southampton
    Thanks for the reply mate.
    Would i be checking for splits in boost pipe(s)?
    southampton
    I took it back to the dealer, where they said the same and replaced a boost pipe that was split. Everythings been fine until last night when it happened again.
    Will update this thread so its of some use to others in the future... nothing worse than reading a whole thread just to get to the end and not find out the outcome!
    southampton
    Had the car looked at again, luckily under warranty... this time its had a new mass air flow meter. Hopefully will sort it!
    jilava
    Does it drive better under 2200 rpm with the new MAF?
    southampton
    Um, no! It's going back AGAIN tomorrow... will keep you posted on what they do next! Maybe egr valve but would that cause it to go into limp mode on full load?
    Ashington, Northumberland
    I would remove, strip and clean the EGR valve and also the boost sensor. two extremely common faults, especially the EGR valve.
    southampton
    Ok, well if they don't get to the bottom if it, I'll try the suggested fixes. But I'm slowly losing faith as I've only owned it a week! :-(
    southampton
    Dropped it off, mechanics lead to believe it could be the turbo actuator?
  1. Spanner light & loss of power
    By kamar in forum Troubleshooting
    Last Post: 9th January 2013, 23:10
  2. Replies: 0
    Last Post: 26th August 2012, 03:15
  3. Spanner light on but no loss of power
    By jonesy1 in forum Engine & Drivetrain
    Last Post: 1st May 2010, 12:58
  4. Loss of power and spanner light!
    By martinhill in forum Engine & Drivetrain
    Last Post: 3rd February 2010, 18:48
  5. Spanner light and loss of power on 3.0 CDTi
    By dgh in forum Engine & Drivetrain
    Last Post: 21st March 2009, 23:20
vauxhall vectra 3.0 cdti spanner light on
vauxhall insignia spanner light loss power
