Thread: Insignia low fuel pressure - common problem
    Leicester
    Default Insignia low fuel pressure - common problem
    Hi,
    The title says it all and this post is linked, in a way, to my other post.
    My Insignia wouldn't start after being driven ok for a few miles. After turning on the ignition when restarting the car (after a few mins of sitting still) the car turns but doesn't start. It just judders.....
    The AA measured the fuel pressue which was 1.4 bar, whatever that means. Is this the problem, does it sound right?
    If you were to leave the car sitting for a while, it will eventually start again, but I have had it recovered to the dealer as I had it literally hours with this happening twice.
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Pressure in the CDTi common rail is something stupidly high, in the hp rail its about 1600bar upwards!
    Leicester
    And that is why it wouldn't fire up?
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    not had any experience of the insignia to be fair, so couldnt tell you. Also it depends where he was measuring the fuel pressure...
    Leicester
    Hi,
    it is now fixed, a relay problem or something - not a clue about mechanics...
    Regular Member grumpano's Avatar
    North West
    Glad its sorted mate. How did you go on at the dealers?
  1. Help!! Dreaded fuel pressure problem
    By piriemr in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2012, 20:41
  2. Anyone with a Z22YH .. NOT had the Fuel Pressure problem?
    By ShamusUK in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 14:30
  3. fuel pressure problem
    By officerbel in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 11:18
  4. Tonight on BBC's Watchdog - Vauxhall fuel pressure regulator problem
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2009, 18:53
  5. H.p fuel pump pressure regulator problem 2.2 direct
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd August 2009, 18:06
2011 insignia cdti rail pressure low
insignia fuel pressure regulator
vauxhall insignia low fuel pressure
insignia low fuel pressureinsignoa fuel regulatorinsignia diesel fuel pump probleminsignia cdti fuel pressurewhat does the fuel pressure regulator do on the vauxhall insignia cdtivauxhall insignia fuel pump problemsinsignia cdti fuel pressure regulatorinsignia fuel pump problemsvectra fuel pressure lowhow much fuel pressure should be on vauxhall insigniawhere is the fuel pressure for vectra c locatedinsignia fuel pressre problemsopen insignia low fuel pressure fuel pressure regulator insigniainsignia cdti pressure regulator
