Thread: Bit of advice please.
    Basildon
    Default Bit of advice please.
    Hi, I've had just my 06 SRi CDTi serviced end of last week, all was good as gold before hand.
    Having drove it home from the garage I noticed a little smoke coming through the air vents. I had a quick look under the bonnet and it was coming up from behind the engine. Thought nothing of it, possibly a little burnt oil/fluid burning off as the engine got warm.
    Went out in it for the first time since having it serviced and half way down the road noticed the battery light on. Few minutes later the ABS light came on and then the engine managment light followed by a loss of electrics.
    Pulled over and turned the engine off, looked under the bonnet and the smoke was once again coming from behind the engine. Needless to say it would not start anymore (battery flat as pancake)
    Having had a deeper look there appears to be alot of fluid (smells of diesel) round the alternator and surrounding cables, the sheafing surrounding some of then is soaked in it. Also theres a fair bit spilt on the tray below the engine.
    Based on the above does anyone have any suggestions on possible faults?
    Thank you in advance
    salisbury
    sounds like someone hasn't done the fuel filter up properly as the filter is under pressure, can you see any diesel anywhere?
    PRESTON
    all those parts are bang where the fuel filter is. Either it's not tightend correctly, or they splilled alot when changing the filter.
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    If your still stuck tomorrow I can pop in to basildon on the way home from work and stick my head under the bonnet if you want? The fuel filter assembly loose could well be the cause of the diesel leak, if its diesel that is....
    Doesnt explain the ABS and loss of electrics though unless its goosed the alternator?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    PRESTON
    i was thinking along the same lines re the alternator plasma. if it's been drenched it might well have goosed it. Be interesting to know if this is the cause of leccy issues.
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
