Results 1 to 10 of 14
Thread: Following How 2
    Regular Member robster23's Avatar
    Hastings
    Default Following How 2
    On the rear brake pad change.
    Got the first one off and am winding in the caliper but it is winding forever, is this right? Doesn't appear to be moving!
    Help!
    cambs
    it need to be pushed aswell
    Hastings
    Cool. How hard?
    Regular Member danlat1415's Avatar
    Lancashire
    Treat it like a medicine bottle lid...
    If you just turn, it'll turn forever. You need to push and turn at same time.
    Pretty hard, easier to use the correct tool. Also are the two sides different threads? One left hand and one right hand?
    Edinburgh
    I would say its just as easy to use a g-clap and put the bit you turn on the piston because it also turns the piston as well as pushing it. If you won't have a g-clamp, a pair of needle nose pliers in the two holes, give it a good push in as you turn it. done in 30 secs.
    special tool = waste of money
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by danlat1415 View Post
    A very simple and easy description,i will remember that
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    Quote Originally Posted by robster23 View Post
    Help!
    Ive just done mine m8, screw clockwise in both sides.
    I used needle nose pliers to screw back then used the tool push the piston back, it turned a little while going back but slipped a bit as the two pins had been ground off for another job.
    Trim : Sport
    Engine : Petrol
    This is the correct t0ol to use.
    cambs
    Quote Originally Posted by DTI View Post
    what kind of abuse have you given that handel
