Thread: Cdti cat removal how hard
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default Cdti cat removal how hard
    Hi all I have a cdti estae with a dpf fitted does my car also have a cat I think I can see it bolted onto the bottom on the turbo
    Question is how hard is it to take off the cat so I can smash te insides out then re fit the cat
    is it easy looks like a pig will I have to remove front number etc etc or can I remove it from below the engine
    Hope you guys can shed some light cheers
    kings lynn, norfolk
    bump
    Regular Member storm's Avatar
    Northumberland
    i wouldnt mind trying this if anyone knows how etc?
    EVERYWHERE
    There must be at least a hundred threads on this subject if you can be bothered to use the search feature.
    kings lynn, norfolk
    Hi there I have looked in the search and can see posts about removing it g
    and pros and cons but nothing to actually tell me how to remove it and tools needed and what sort of accsess I need to make to get to it
    Any help would be much appreciated also has any one on here done I diy decat and knocked the insides out I did this on my mondeo I had and noticed more power and more mpg and it flew through the soot test on mot
    West
    bashing the inside of the cat out will reduce back pressure & could lose a bit of torque, you're better off removing the cat altogether & have some tubing welded in it's place
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    My CDTi has a Cat after the flexi in the downpipe which the clamps to the middle section of the exhaust, so to decat this it would need cutting after the flexi and a piece of replacement pipe fiiting. I'm not sure where the DPF is in relation to the CAT, before or after. I've also heard some mention of pre-cats in the downpipe....but down know if they are on Vectra.
  1. vectra cdti hard to start
    By vo04lan in forum Engine & Drivetrain
    Last Post: 12th December 2012, 00:23
  2. vectra 1.9 cdti 120 hard to start
    By droops98 in forum Engine & Drivetrain
    Last Post: 4th May 2011, 16:45
  3. hard blowing noise from vec c v6 cdti v6
    By v6 sri diesel in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2011, 00:04
  4. Cdti pre cat removal
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 7th September 2010, 18:01
  5. V6 CDTI sometimes hard to start
    By Celes in forum Engine & Drivetrain
    Last Post: 14th July 2010, 10:48
vectra c cat removal www.vectra-c.com
