Thread: Door mirror and bulb change help
    Regular Member daviem-rfc's Avatar
    SUNNY DUMBARTON
    Default Door mirror and bulb change help
    Well was down at my local car wash and whilst they were pressure washing my door mirror it smashed to pieces so I now have the new mirror and dont know how to fit it, help. Also one of my fog lights is gone are these easy to change? Thanks in advance
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    I see you got a pre facelift so reference to your fogs it's easy. I changed both my bulbs yesterday for some Ultra H3's so they are nice and white now. Anyway, i found it easier to jack the car up a little so i could get under, then remove the covers on the bottom of the foglight. The bulbs are held in place by a spring type wire which are just clipped on to a couple of prongs. The wire for the foglight is a spade type but be careful as mine were really tight to remove and then your ready to fit your new ones.
    Just be careful though NOT to touch the bulb glass as the oil from your fingers could make the bulb explode.
    SUNNY DUMBARTON
    Is H3 the bulb code or is that a type of bulb if so where would I find them?
    VOTING UKIP IN AVELEY
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    ebay or halfords.for the bulbs.....H3 is the code for them
    the mirror glass you just have to supa glue on
    Jan 2010
    Luton, Bedfordshire
    Trim : VXR
    Engine : 2.0t
    As Soulman states the bulb type is H3, as for buying bulbs it depends what ones you want to go for. Halfords wanted £20 per bulb when i looked yesterday but then i went to Carnoisseur and bought the Ultra's for £12.99 the pair (they must have charged me the wrong price as the pack behind said £24.99).
    SUNNY DUMBARTON
    With the glass its the full glass unit not just the glass. How do I get that off as im sacred I might break it
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    just fold the door mirror in ...then if you push the glass forward it should just unclip
    Regular Member old cruiser's Avatar
    slough
    Quote Originally Posted by daviem-rfc View Post
    When you say full glass unit, I take it it's the VX one that has the two metal tags on it for the heated connections? if that is the case, then just put yours fingers in between the mirror surround and the black plate that's left from where the glass was attached and just gently lever it out, the black plastic plate will pop out, fitting is reversal of removal, but just be aware that there are two wire connections behind this plate that will need to be connected to the new one. HTH
    Cheers Pete
    Mileage : 000
    I am lead to belive there are Two types of mirror fitting. The one is easy to do the other is not so easy. If you put your fingers behind the plastic backing plate that is still left on the mirror pull it gently it should pop off. Replacing the new glass you just need to push firmly not too hard in the centre 2" diamiter of the glass to get it to clip on.
    If you have heated mirrors you will need to pull the Two conections off.
    These are photos of the "easy" type to change.
    SUNNY DUMBARTON
    Mirror changed, thanks for the pictures thats what I had to change.
  1. Door mirror scrape, can i change the body colour part?
    By johns159 in forum Insignia car chat
    Last Post: 8th June 2010, 15:25
  2. Bulb change
    By chris_gsi23 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 18:33
  3. how do you change this bulb?
    By wardy in forum Bodywork & Interior
    Last Post: 1st March 2008, 09:45
