Thread: change glow plugs
    Edinburgh
    Default change glow plugs
    I'm going to change the glow plugs on my 06 1.9CDTi [150] however when I previously had an Astra (2.0 DTi) a garage managed to snap one of the flow plugs in the head and it basically remained stuck there.
    So I'm looking for any tips on getting glow plugs out without breaking them.
    thanks.
    West
    i have'nt done them yet on my 1.9, did do them on my old C 2.0dti, B 2.2dti & zaffy 2.0dti with no issues...
    I usuall spray wd40 around the tops of the threads & leave to soak overnight or a good few hour prior & warm the motor up slightly too.
    hth
    Edinburgh
    yeah, soaking with wd40 was my thinking cause it should penetrate the evaporate and if it goes right through into the engine it shouldn't do any harm.
    Jun 2006
    Near Edinburgh
    They should be pretty straight forward to do, the 4 of mines came out without any issue and they werent sprayed with lubricant prior to removal.
    Regular Member the fisherman's Avatar
    manchester
    they are quite hard to get out lol,as i watched my freind do them on mine,saying that it only took him about 45 min to do all,its just i think the odd 1 is hard to get to,but youll manage lol
    Edinburgh
    I'm expecting the worst since my sump plug is stuck fast, presumable because the last owner had it serviced at Arnold Clark who probably put the plug in to TAF.
    manchester
    good luck with it mate.have confidence and youll manage
    Edinburgh
    all four changed with no hassle. thanks for your assistance chaps. copper greased the new ones so hopefully it won't be an issue next time
  1. how to change glow plugs on 1.9cdti
    By mr.4dil in forum Diesel Engine related
    Last Post: 11th May 2011, 20:01
  2. Glow plugs change
    By deeks in forum Diesel Engine related
    Last Post: 21st April 2011, 15:47
  3. 1.9 cdti 150/ How often should you change the glow plugs?
    By richiem in forum Engine & Drivetrain
    Last Post: 14th January 2011, 15:16
  4. Change Glow Plugs on 120 CDTI
    By RS_Turbo in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2009, 09:28
  5. how do i change the glow plugs
    By tim wood in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2008, 21:25
change vauxhall vectra glow plugs
