Thread: Airbox Mod and Boost Sensor Clean
    Regular Member dolf.peeters's Avatar
    Nov 2009
    Eire
    Default Airbox Mod and Boost Sensor Clean
    I dont have priveleges to post in the 'How 2' section so here I go
    I today remove the bottom cover from the airbox [http://www.vectra-c.com/forum/showthread.php?t=15122] and cleaned the boost sensor [http://www.vectra-c.com/forum/showth...t=boost+sensor] the sensor was fairky dirty!
    I dont think it made a difference in speed/torque, however ..... it did make a difference to how she drives.
    the car is much more responsive, feels smoother on acceleration and on decelaration the car was slight schuddering [as if it was in to high a gear] => this is now completely gone.
    Regular Member R-ford_Vec_C's Avatar
    St Helens
    What would be the effect on my MPG if I were to do this?? I'm not a fast driver, quite slow infact (being a professional driver) but Its nice to know it's a little more torquey if I ever needed it.
    Regular Member danlat1415's Avatar
    Lancashire
    Do you know if this is just for Deisel cars, or do the Petrol versions have a 'boost sensor'?
    Nov 2009
    Eire
    Quote Originally Posted by R-ford_Vec_C View Post
    I only drove it for 40mins after, should be able to tell you tomorrow eveining after driving to and from work
    Quote Originally Posted by danlat1415 View Post
    to be honset with you I dont know, I got my info from the 'how 2' section
    I'm hoping to clean the EGR next time round
    Cambridgeshire
    A boost sensor is only found on turbo cars and does what it says on the tin mate
    Lancashire
    Quote Originally Posted by parsco View Post
    Thanks.
    Do you know if there is anything similar on the Petrol models which I can 'clean' in a similar way for similar results?
  1. Boost sensor clean
    By Ruffus2 in forum Engine & Drivetrain
    Last Post: 14th August 2012, 18:22
  2. Clean boost sensor?
    By mikeq in forum Engine & Drivetrain
    Last Post: 15th June 2011, 17:57
  3. Boost sensor clean!.
    By felixx in forum Engine & Drivetrain
    Last Post: 18th July 2010, 23:37
  4. de badged, airbox mod and clean boost valve
    By li4m in forum Quick Photo Album
    Last Post: 4th January 2010, 19:34
clean boost sensor vectra c
vectra c boost sensor clean make my car more responsive
