Results 1 to 10 of 14
Thread: oil and filter change on 1.9 cdti facelift
    Regular Member lutontownfan's Avatar
    Nov 2009
    colchester
    Default oil and filter change on 1.9 cdti facelift
    Tried this job today and found access really hard with engine covers etc. I wanted to run the car up on ramps but my spoiler is too low at the front and would damage it. Anyone got any other ideas of doing the job safely.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    jacks and axle stands
    Nov 2009
    colchester
    I got a couple of trolley jacks but would they get the car high enough from the wheel jacking points for access to the sump?
    Regular Member mikeeaston's Avatar
    widnes
    what sort of ramps you got mate
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    take it to your local national tyres/oil and filter £35..........castrol edge
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    didn't know if you could jack one side up axle stand, then the other and axle stand that up
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Yeah I have done many of times on my veccy chock rear wheels then put in gear with handbrake on tight and then jack up one side using jacking point place axle stand on front subframe nearest the edge of the car then same other side and bingo
    Admin plasma's Avatar
    On the Forum
    310 Post(s)
    Engine : 150
    Mileage : 74000
    Jack the car up put it up on axle stands.... Remove underbelly tray makes access to the oil filter a damn sight easier... Its still pig ackward to get at with little room for movement but its the best way to do it...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Nov 2009
    colchester
    the ramps i got are just regular metal ones but a bit steep they used to work a treat on my veccy b but this car is much lower at the front.
    Nov 2009
    colchester
    ok will try that method with the trolley jack and i have stands too. Just really a point that the ramps used to work very well before and get so much more room to move about under the car too.
  1. oil and filter change cdti 150
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2012, 11:22
  2. Oil filter change 1.9 cdti 150
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2011, 09:39
  3. 3.0 V6 Cdti oil filter change
    By themarbleman in forum Engine & Drivetrain
    Last Post: 26th March 2011, 16:14
  4. Oil filter change on a 3.0 cdti
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2010, 18:40
  5. 3.0 cdti K & N Filter change
    By M&S in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2006, 18:14
