Results 1 to 3 of 3
Thread: TID bulb replacement??
    West Midlands
    Default TID bulb replacement??
    hey,
    Is there anyway of replacing the bulbs in the TID as mine has gone dark and I can't see anything on the display.
    I don't have the code for the radio so I will have to try replacing whatever needs replacing with the TID still connected because if I do discconect it i have a feeling it might lock the radio.
    Any info would be cool. thanks,
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Just remove centre vents and pull it all out and you will see the bulbs on the back,there the twist in ones like on the older vauxhall's.
    To remove vents you need to open glovebox and put fingers under trim on dash and pull,then unscrew the 4 torx screws holding in the centre vent HTH
    Irmscher Insignia CDTI 130
    West Midlands
    hi bigmac, thanks for your quick reply
  1. bulb replacement
    By temprahater in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 22:29
  2. Bulb replacement
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2010, 13:07
  3. bulb replacement
    By clifford in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2009, 20:19
  4. HID Bulb replacement...?
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2009, 19:13
  5. bulb replacement
    By skippyroo in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2008, 00:48
vectra sat nav bulb replacement
vectra c tid bulb
vectra c stereo bulb replacement
