Thread: Spanner Lights on??
    stockport
    Default Spanner Lights on??
    Hi.Came to start my vectra c 1.9 dti this PM and the spanner light came on.
    Also no radio,no blower (even on 4 setting) and no rear screen heating,everything had been working fine when I used the car yesterday. Checked the faults with my code reader and it came up with PO650, (Malfunction of the indicator light control circuit).Does anyone out there know what this means? and does it have anything to do with the problems I am experiencing?
    Hope someone can help.Thanks,Felixx.
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Might be something to do with the CIM.
    stockport
    Default Felixx.
    Quote Originally Posted by danBoy View Post
    Thanks for your reply but what does CIM mean?,and is it expensive?
    Regards,Felixx.
    Mar 2007
    North East
    Yes it's expensive, CIM - Column Interface Module. Check the ABS module plug, plenty of info on here about it.
    stockport
    Default Felixx.
    Quote Originally Posted by rockh View Post
    Thanks for elaborating.I'm not up to speed with some of these abbreviations when people are describing things.Regards,Felixx.
    stockport
    Eek Felixx.
    Thanks to everyone for their input.I have just been out to the car to see if it was still u/s,(as you do when your grasping at straws),when,as I turned the ignition on,there was this awful "crackling/hissing"noise from behind the dashboard,in the general area of the display screen.
    Started the engine,no spanner light !!,radio,blower everything is working again!!!!!.
    Obviously the fault has rectified itself,but s**t,what's going on?.Can anyone shed any light on the problem as I really am confused and more than a little bit worried.
    I would be grateful for anyones thoughts on this matter/problem.Felixx.
    stockport
    As an update,the "buzzing" noise still happens then stops when I turn the ignition on but everything is working o.k.(at the moment),however,there is no fault code showing.Is there any type of capacitor/relay around the display screen area behind the dash?.
    I really am confused.
  1. Spanner lights again
    By jocknz in forum Engine & Drivetrain
    Last Post: 29th September 2011, 13:22
  2. EM & Spanner Lights
    By Gracey in forum Engine & Drivetrain
    Last Post: 30th April 2010, 13:42
  3. spanner lights on
    By timbarny in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2009, 14:33
  4. 03 vectra 2.2 dti auto spanner lights
    By newtovectra in forum Engine & Drivetrain
    Last Post: 29th April 2009, 22:54
  5. spanner lights come on again
    By david-bell in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2005, 21:08
