Thread: brake disk problem
    greenock
    Default brake disk problem
    my mum said my car was making a grinding noise
    i went down and on one back disk theres a small ring ground out the disk
    now its a vec b 2.6 so if i change back disks and pads will this cure the problem or do u think theres something other than brake pad wear causing the problem?
    I'd check the pads for thickness to make sure they are not worn out. When was it making a noise? All the time or just when braking?
    greenock
    when braking
    and it was really really bad just as u were coming to a halt
    i cant understand why its only a 2 cm ring around one disk and not the other
    the disks arent lipped at the edges
    Check the pads. They could need replacing, when were they last done? Or it could be something stuck in it.
    greenock
    wouldnt the back pads wear evenly tho?
    so the whole disk would be scored rather than just a wee ring around the middle of it
    i think there might be something stuck in it
    Maybe maybe not. Only one way to find out. have a look whilst your hunting for whats causing it. I have found pads wear odd in the past, maybe a small amount of friction material on the inside and nothing on the out side.
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Could be a small stone stuck between pads/disks
  1. 3.0CDTi brake disk confusion
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2009, 18:41
  2. Really odd Brake disk wear???
    By redraptor_141 in forum Handling & Braking
    Last Post: 17th August 2009, 21:22
  3. quick brake disk size question
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2008, 12:33
  4. minimum brake disk thickness...
    By david.aka.judas in forum Handling & Braking
    Last Post: 23rd July 2008, 19:17
  5. update disk/2007/08satnav disk
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2008, 19:44
