Results 1 to 10 of 19
Thread: Manifold swirl bar/pots
    N.Ireland
    Default Manifold swirl bar/pots
    I tried a few times on replacing the swirl bar on to the Manifold,it wouldn't stay on, the rubber washers would be wore out in no time and the screw caps would snap off.I noticed the swirl pots (I hope this is the proper name) where becoming looser and fumes would come into the cabin when the car was stationery,also the black smoke out the back end was serious.Last weekend I took a chance and glued(Gorilla glue, Tescos) numbers 1 2 and 4 in the open position,to the right as you look at them,this is were they sit when the engine is running.The car went into limp mode a couple of times the first time I tried it,the bar was still fitted,so I took it off and then it was fine and hasn't limped in a week.There is no smoke out the back now from what I can see or fumes coming into the car.To tell you the truth I don't really no what I've done but it seems fine now.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    fine for now but basically the bottom line now is you really need a new inlet manifold as this will cause extra fuel consumption and other probs too
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Quote Originally Posted by winnie2457 View Post
    true really unfortunately mate
    N.Ireland
    You could end up rite Winnie,but at the minute the car is driving well and this week the wife had the car, the average mpg is usually around 33 with her driving around the town, but from I done this last saturday it hadn't dropped below 37.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    good luck mate
    N.Ireland
    thanks Matt,I'm sure I'll need it..
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    diesel will always make it not had a petrol for 4 years and never again
    N.Ireland
    There's was no harm in trying,I've lost count how many times I read on here about cars getting new Manifolds and there problem appears back again.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    it's just there probs, why i got the v6 cdti
    GRIMSBY
    evening,
    i did the swirl pot fix today and noticed on my car straight away the car went into limp mode.. so i took it for a blast up the carrigeway...
    still no good, the light shaped as a engine came on the dash
    and some blue smoke could be seen
    the car had a flatspot before but ran fine i wish i hadn't done this fix now
    is it just burning off excess oil or has the engine been damaged in some way..
    any help would be very appreciated
    sorry to but in on the thread...
  1. Are my swirl pots leaking?.
    By felixx in forum Engine & Drivetrain
    Last Post: 2nd August 2010, 21:15
  2. Checked the Swirl Bar and pots-think they are OK, please check!!!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 22nd May 2010, 14:29
  3. 2.2DTi blue smoke after fiddling with "swirl pots"
    By Celes in forum Engine & Drivetrain
    Last Post: 19th March 2010, 00:45
  4. cleaning the swirl pots
    By monty2000 in forum Engine & Drivetrain
    Last Post: 16th March 2010, 14:28
  5. CDTI 150 swirl pots
    By crgv6 in forum Engine & Drivetrain
    Last Post: 20th June 2009, 13:24
