Results 1 to 3 of 3
Thread: Vectra C 2.2DTH P0335 P0638 P0100 DTC
    Jul 2006
    omagh
    Default Vectra C 2.2DTH P0335 P0638 P0100 DTC
    I have a 2.2 DTH Vectra C. Recently when accelerating hard over 3500 RPM my spanner light comes on the dash and lights up. So i checked the trouble codes and they came up as P0335 Crank shaft sensor, P0638 Throttle control circuit high AND P0100 Mass air flow sensor circuit. After re-setting the codes i took the car for a drive and straight away it done the same, so i checked the codes again and P0100 came up on its own. So i purchased a new air flow meter thinking that i had solved the problem. But sure enough it done the exact same thing!!! Has any one any bright ideas PLEASE HELP
    Regular Member philzi's Avatar
    East Yorkshire
    how are you checking the codes?
    Jul 2006
    omagh
    By using Tech 2, I have since discovered that i had a damaged wiring loom going to the crank sensor so i have repaired that but still having probs with the P0100 Mass air flow fault...
  1. Replies: 4
    Last Post: 18th August 2017, 06:54
  2. P0638
    By tomo610 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st July 2012, 19:29
  3. p0335 crankshaft sensor open circuit
    By jon1.9cdti in forum Engine & Drivetrain
    Last Post: 28th July 2010, 11:52
  4. VEC-B HELP, P0335 Crank Sensor-CAR WONT START
    By Vaux-Man-G in forum General Chat
    Last Post: 26th October 2009, 23:25
  5. OBD Fault Code - P0335
    By patsy111 in forum Engine & Drivetrain
    Last Post: 20th October 2008, 22:13
p0638 opel vectra c
p0100 en vectra 2.2 diesel
p0638 опел not start
p0638 p0100 opel vectra c 2.2
