Thread: abs
    oxfordshire
    Default abs
    hey
    just wondering if any1 can help me my abs light keeps coming on what do i look for as possible problems
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    best bet is a fault code read, otherwise you'll just be chasing around possible things which may or may not be the problem.. Usual causes are abs sensor rings (part of the hub) the wiring from them to the connector under the wheelarch, (cant get loose/bad connections)
    oxfordshire
    Default ....
    will the car fail mot with abs light coming on
    Jul 2009
    The Rift, Cardiff
    Quote Originally Posted by 5008tony View Post
    Yes
    http://www.motuk.co.uk/manual_340.htm
