Thread: Corsa-C Gear Linkage
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Default Corsa-C Gear Linkage
    Hi all,
    Anybody had any experience changing the gear linkage on a corsa-c? Appears to be a common problem which has just affected my other half's car (04 plate, 68k). Having read a couple of forums it seems to be a straight forward change, it just looks like a sod to get to it!
    People have been quoted/charged £200+ to S&F the part, yet I can find replacement modified parts on the bay for £20, so I'd rather save 90% and change myself if I can.
    Any help/advice/comments appreciated.
    Thanks.
    did one about 6 weeks ago
    really easy , its held onto the linkage at the gearbox by a pin and under the car its got a splined shaft to remove by undoing a pinch bolt
    the last thing holding the linkage onto the gearbox casing is a plastic clip that you break to get it off , but make sure there is a new one in the box
    once its done , reset the linkage and you'll be amazed by how tight the gearchange is
    good idea to get a haynes manual it does tell you in detail how to do it
    Winchester
    Excellent, thanks. Will be picking up the Haynes manual later.
    Did you use OEM parts, or and aftermarket modified version?
    sorry for delay it was just a pattern part off ebay , cost about £16
    couldnt believe how tight the steering was after it was done
    Glasgow
    Quote Originally Posted by marktaylor View Post
    Must have been a super duper new gear linkage if it made the steering nice and tight lol
    Quote Originally Posted by byebyeitsagsi View Post
    good spot ......... my bad
    Winchester
    Just an update, ebay part (http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=330358332062) fitted nice and easily. It's like a new car!
    told you it wasnt difficult
  1. Gear linkage knackerd
    By stitchi1973 in forum Suspension, Wheels & Brakes
    Last Post: 29th October 2009, 14:32
  2. Manual Gear Linkage ?
    By 900ss in forum Engine & Drivetrain
    Last Post: 24th June 2008, 14:14
  3. Gear linkage cables
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2006, 15:19
