Thread: spraying laquer
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default spraying laquer
    any advice on spaying laquer from an aerosol , i have no prob priming and then using colured paint , all is good
    seem to always mess the job up when it comes the final stage
    Sodding Typical on Sea
    Make sure the object is warm, not hot and apply light coats if you can warm the can over too very lukewarm I find helps it not bloom, and build it up. that way it can be cut and polished back.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    dont over do it on first coat, just a few sprays then wait till its tacky and do it again
    Regular Member crespo's Avatar
    Bournemouth
    Put the can in warm water for a while before you use it. This will help.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    spray the first coat let it dry and then wet coat it...(as in spray closer and dont let it dry propperly applying it so it's just before it runs) thats what i do and i get a dammmmn good deep glossy finish like this....
    Midlands Mod Shop - NFFC.
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    I do the same as Rich on the lacquer.. First coat to seal it, then 2nd coat almost to the point of running so it keeps a wet look Very fine line between looking wet and running though!
    Trim : Get a
    Quote Originally Posted by plasma View Post
    and by god when you get it right it's qualitay.....
  1. laquer peeling off??
    By Jow20 in forum General Motoring Chat
    Last Post: 12th March 2012, 17:54
  2. Carbon Wrap & Laquer...
    By jimbojetset in forum Detailing and Car Care Discussion
    Last Post: 3rd June 2011, 16:41
  3. Help with laquer
    By gibbon7000 in forum The 'Off Topic' room
    Last Post: 29th March 2009, 02:19
  4. Clear Laquer Question
    By tallica371 in forum Bodywork & Interior
    Last Post: 9th December 2007, 00:21
  5. Minor scratch in laquer - removal
    By IrmscheRay in forum Detailing and Car Care Discussion
    Last Post: 23rd October 2006, 08:45
